Thread: FYI - Don't overfil your tank.. When it stops, consider it full.
Results 1 to 20 of 29
  1. #1 FYI - Don't overfil your tank.. When it stops, consider it full.
    SE Level Member midrange's Avatar
    Belleville, Ontario
    Hey guys and gals
    So yesterday I was driving the car and the check gas cap light came on. So I did, and i couldn't get the light to go off. Today when getting some other work done on the car i told them, and they got rid of the light, and so far so good.
    I never had the light come on before but last time i filled up, I filled it right up. The garage said that these cars and some other cars, when you fill it up too much, the gas can get in the gas cap and damage the charcoal filter in the gas cap causing it to not do its job.. Makes sense.
    So if my light comes back on, i'll assume thats the what caused it to fail, so i'm sharing what I was told to hopefully avoid it down the road.
    WHen it the gas pump shuts off, consider it full!
    2004 Grand Prix GT1
  2. #2 Re: FYI - Don't overfil your tank.. When it stops, consider it full.
    Donating Users wulfpack06's Avatar
    KCMO
    i dont have this issue....
  3. #3 Re: FYI - Don't overfil your tank.. When it stops, consider it full.
    Belleville, Ontario
    It may or may not cause an issue.. I was just passing on what I was told.
    2004 Grand Prix GT1
  4. #4 Re: FYI - Don't overfil your tank.. When it stops, consider it full.
    SE Level Member Truckin2001's Avatar
    South GA
    Mid - Thanks for the tip and I will keep it in mind when I fill up!
  5. #5 Re: FYI - Don't overfil your tank.. When it stops, consider it full.
    GTX Level Member Steel Armadillo's Avatar
    Orlando, Florida, United States
    I never have money to fill it all the way up anymore
    Damn college...
    The evil LG8 still refuses to die.
  6. #6 Re: FYI - Don't overfil your tank.. When it stops, consider it full.
    Omaha, NE
    I disagree with this... You should have a check valve in the fuel neck on your 04. Also as far as I know there's no charcoal in gas caps since the 80s. That's what we have evap systems for.
  7. #7 Re: FYI - Don't overfil your tank.. When it stops, consider it full.
    Nov 2011
    Omaha, NE
    Also there was a report that said topping of your gas can give you cancer. I guess because the fumes can escape and eventually cause cancer.
  8. #8 Re: FYI - Don't overfil your tank.. When it stops, consider it full.
    Charles City, IA
    Topping the tank off can fill up the charcoal canister and ruin it, does not happen very often but it does happen.
    SMGPFC Two Nipple General
  9. #9 Re: FYI - Don't overfil your tank.. When it stops, consider it full.
    Kansas
    Just topped it off about an hour ago.... cause racecar.
  10. #10 Re: FYI - Don't overfil your tank.. When it stops, consider it full.
    Feb 2010
    TN
    Bought my GT new in 1997 been topping it off everytime I fill it 300,000 iles and have not had this issue. and I agree with Spade there is no charcol in the cap I would be looking for a ne mechanic
  11. #11 Re: FYI - Don't overfil your tank.. When it stops, consider it full.
    i have to top my car off. if i dont see even numbers on the gas pump my whole world ends.
    SE Level Member Compg4me's Avatar
    Dec 2011
    Grand rapids Mi
    I'm OCD like that as well.
  13. #13 Re: FYI - Don't overfil your tank.. When it stops, consider it full.
    Ohio
    haha me 3. ive not been caring as much lately about it but it still gets me once in awhile
  14. #14 Re: FYI - Don't overfil your tank.. When it stops, consider it full.
    Kansas
    Unless you think logically like I did today. Got fuel for $38.28, got a Mt. Dew... total came out to $40.00... like a bauce.
  15. #15 Re: FYI - Don't overfil your tank.. When it stops, consider it full.
    I live here. TLSheff's Avatar
    I've done that before. Figure in gas, chips, a 1lt, and tax and get it square on $50.00.
    Lady at the register looked at me like wow... really?
    F_CK YEA
  16. #16 Re: FYI - Don't overfil your tank.. When it stops, consider it full.
    Kansas
    I do that all the time... but also figure in the discount. If you pay w/ cash you get a 5% discount.
  17. #17 Re: FYI - Don't overfil your tank.. When it stops, consider it full.
    Jun 2011
    Detroit, MI
    Overfilling the tank wouldn't cause the gas cap to leak lol. The evap system on these cars often sets off the ses light on our older cars. Mine will have the "small evap leak" code for forever now, not a big deal at all. It detects a leak as small as .04" inches.
    iLoveSpade
  18. #18 Re: FYI - Don't overfil your tank.. When it stops, consider it full.
    Banned
    CT
    IDK about you guys, but when I'm "filling up" after it clicks, I can put another 4 gallons in until it's topped off.
  19. #19 Re: FYI - Don't overfil your tank.. When it stops, consider it full.
    SWPA
    I always top off and never have an issue. I'm OCD about even amounts too.
  20. #20 Re: FYI - Don't overfil your tank.. When it stops, consider it full.
    SE Level Member dert's Avatar
    Jul 2011
    Big Rapids, MI
    I was told not to overfill because of that issue in school too and saw a couple related problems when i worked in a shop. Doesnt always and wont always cause a problem but i agree it for sure can.
  1. Full tank of fuel gauge floats between full and empty.
    By johnnyb in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2013, 06:17 PM
  2. new pcm. hard downshift from 2nd to 1st at stops??
    By colindunn in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-18-2010, 07:10 PM
  3. Eibach's and the bump stops
    By FuglyGTP in forum Brakes/Suspension/Chassis
    Last Post: 08-18-2010, 12:18 PM
  4. better gas mileage when tank is full/almost full
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-07-2010, 09:53 AM
  5. Metal Gas Tank Flap Broken off and Into Tank
    By indplsin72 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2008, 08:35 PM
