Thread: How many exhaust insulators do I need?
Results 1 to 18 of 18
  1. #1 How many exhaust insulators do I need?
    GT Level Member firstdue's Avatar
    Toledo, Ohio
    After putting a few hundred $$ into my front end, I'm looking to do an inexpensive fix and lift my sagging exhaust tips. I've seen the post about using an adjustable clamp to tighten then up, bit would rather spend a few more $$ and replace the older failing part. I'd look under the car myself but its sitting on 3" of snow. How many of the insulators do I need? And a part # would be great too! Thanks!!
    Sent from my DROID RAZR using Tapatalk
    2009.1 Liquid Red G8 GT
    2001 Grand Prix GT Bright Red
  2. #2 Re: How many exhaust insulators do I need?
    just get new rubber exhaust hangers.
    Toledo, Ohio
    Right, I think the part description calls it an exhaust insulator.
  4. #4 Re: How many exhaust insulators do I need?
    Donating Users
    Deland, IL
    what year car? i found these for a 2002 gtp, rockauto.com
    WALKER Part # 35352 Insulator
    FRONT WHEEL DRIVE; Dual Exhaust
    $0.98
    AP EXHAUST Part # 8166 Exhaust System Hanger DUAL EXHAUST, SINGLE EXHAUST $1.16
    WALKER Part # 35460 Insulator
    FRONT WHEEL DRIVE; Dual Exhaust; Right Hand or Left Hand $2.58
    AP EXHAUST Part # 8202 Exhaust System Hanger DUAL EXHAUST, SINGLE EXHAUST
    Left; Dual Exhaust
    Right; Dual Exhaust $3.28
    Toledo, Ohio
    01 GT, thanks!
    Toledo, Ohio
    I'm gonna try and find an exhaust layout that would show the placement and quantity.
  7. #7 Re: How many exhaust insulators do I need?
    Should be like 7 of them.
    2 that hold the middle up where the Cat converter is. 1 where it bend around the gas tank to the Y, then the mufflers each have 2 that hold them up.
    Toledo, Ohio
    Thanks!! I'll be sure to post some before and after pics.
  9. #9 Re: How many exhaust insulators do I need?
    Toledo, Ohio
    Ok, I replaced the 4 hangers in the back end of the muffler. It lifted the tips a little, and my left side is still a little low. I don't think you want these too tight into the bumper or they'll start melting it. Definite improvement but i think it could be a little better. Sorry about the crappy cell phone pics.
    Before
    After
  10. #10 Re: How many exhaust insulators do I need?
    you can bend the hangers a bit to lower it or even it out.
  11. #11 Re: How many exhaust insulators do I need?
    Nov 2011
    NY
    Toledo, Ohio
    Thanks! I'm just wondering where they should sit.....like they did when new. I have to look at the brackets to see how they can be bent to lift that left tip just a bit.
    I just looked at old pics of my 00 GT and the left tip on it sat slightly lower too.
  13. #13 Re: How many exhaust insulators do I need?
    GT Level Member 2000GrandPrixGT2000's Avatar
    Trevose, PA
    Hey firstdue, which insulators did you order from rockauto?
    2000 Grand Prix GT- DIY Spectre HAI, KYB GR-2 Struts, GMPP Front and Rear Sway Bars, GMPP Front and Rear Strut Tower Braces w/ Don Rome Brackets
    Soon to be Installed: Poly Bushings + Poly End Links- Front and Rear GMPP Sway Bars
  14. #14 Re: How many exhaust insulators do I need?
    Toledo, Ohio
    I ordered part # 10231659 from Pace Performance. Same part # on the old ones i removed.
  15. #15 Re: How many exhaust insulators do I need?
    Trevose, PA
    How many did you replace? just the 4 in the back or did you replace all of them?
  16. #16 Re: How many exhaust insulators do I need?
    Toledo, Ohio
    I just did the 4 in the back, but will probably add the rest to my next order from Pace (I want to get the front and rear strut tower braces too). They are pretty easy to replace and i did notice the ones further up the exhaust were stretched out.
  17. #17 Re: How many exhaust insulators do I need?
    Dec 2008
    Lawndale, CA
    I replaced all of mine as my exhaust was sagging and bagging around on the sway bar. I did do the hose clamp mod to level out my tips.
  18. #18 Re: How many exhaust insulators do I need?
    Topeka, KS
    I got a whole set from Morad Parts Company - 3800 Motors, Transaxles, & Stock Parts for 15 bux if i remember right.
  1. 3.1 water coming from exhaust leak on exhaust manifold
    By ibhuff in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-21-2011, 01:54 PM
  2. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
  3. VRS EXHAUST- Mandrel Exhaust kit.
    By Lion29GTP in forum General Tech Discussion
    Last Post: 03-18-2009, 02:47 AM
  4. VRS EXHAUST- Mandrel Exhaust kit.
    By Lion29GTP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-18-2009, 02:43 AM
