Thread: Lost controls for heat and air
Results 1 to 15 of 15
  1. #1 Lost controls for heat and air
    Aug 2011
    'Merica
    All. I have a 2003 GT and have lost the controls for the heater and the air. 1 hasn't worked for years, but this morning on my way home i heard a pop then nothing. It won't turn up. Other than the fuse, what could be the problem? I haaven't checked teh fuse becasue it is cold outside.
  2. #2 Re: Lost controls for heat and air
    It should work on 5 at least unless its a fuse or blower motor.
  3. #3 Re: Lost controls for heat and air
    Aug 2011
    'Merica
    Does not work on any setting. I have never heard a fuse pop that loud which make me think it is something else. Where is the blower motor?
  4. #4 Re: Lost controls for heat and air
    under the glove box. Hit it with your hand and see if it does anything. If not check your fuse.
  5. #5 Re: Lost controls for heat and air
    Aug 2011
    'Merica
    I imagine that is what it is since the poping sound came from that side of the car.
  6. #6 Re: Lost controls for heat and air
    Let us know what you figure out. It's warming up outside now, not much though.
  7. #7 Re: Lost controls for heat and air
    Aug 2011
    'Merica
    i have to leave in an hour and a half so I will try it then. If smacking the glove box area doesn't help i will check the fuse tomorow since I will have a place in a garage that is warm. Thanks for the help. I will update probably Monday.
  8. #8 Re: Lost controls for heat and air
    There will be a piece of carpet on the underside of the glove box and you'll have to remove that to see the blower motor. Give it a good whack with your hand and see what it does.
  9. #9 Re: Lost controls for heat and air
    Aug 2011
    'Merica
    So, Saturday afternoon the controls still did not work after giving the motor a smack. About 10 minutes into the trip I turned it to 5 and nothing, but 2,3,4 now work, but 5 still did not. On Sunday nothing worked againt the first but after turning to 5 then back the 2,3,4 worked again and this time 5. This morning the same thing. I am going to check my fueses on lunch, but I have noe lost the windshield washer control. I know it does freeze in Ohio during winter, but it still gives a humming when it is working, but now nothing. I will know more after I check the fuses, but i am going to guess the fuses are fine.
  10. #10 Re: Lost controls for heat and air
    Blower sounds like some sort of electrical short. Maybe a bad resistor or ignition switch?
  11. #11 Re: Lost controls for heat and air
    Aug 2011
    'Merica
    I have heard of the resistor being bad and the key won't come out from time to time. I just press the button under the column to remove the key. Where is this resistor?
  12. #12 Re: Lost controls for heat and air
    the resistor is right behind the blower motor. You'll have to lay upside down in your pass seat to see it. I've change a couple they really aren't that bad.
  13. #13 Re: Lost controls for heat and air
    Aug 2011
    'Merica
    Everything works again?!?!? The only thing that doesn't work is setting #1 and that hasn't worked for quite some time. Thanks for the help.
  14. #14 Re: Lost controls for heat and air
    don't worry it'll break again one day lol they always do
  15. #15 Re: Lost controls for heat and air
    Aug 2011
    'Merica
    I imagine it will be sooner rather than later, but that comes with owning a Grand Prix or a GM product for that fact.
  1. lost key pad
    By Onthebrinc in forum General Tech Discussion
    Last Post: 10-23-2011, 07:54 AM
  2. I'm lost here, please help
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-18-2011, 08:06 PM
  3. Data screen and heat/ac controls shut off
    By Jaymz00 in forum Audio, Security & Visual Electronics
    Last Post: 06-23-2011, 12:48 PM
  4. lost mpg
    By angie in forum General Tech Discussion
    Last Post: 12-20-2010, 10:59 PM
  5. I lost :(
    By nawarkk in forum Track Sessions and Kills
    Last Post: 11-06-2009, 04:00 PM
