Thread: Can't break free front axle nut.
Page 1 of 5 123 ... LastLast
Results 1 to 20 of 82
  1. #1 Can't break free front axle nut.
    GT Level Member firstdue's Avatar
    Toledo, Ohio
    OK I went to advance this morning and picked up two outer tie rod ends and a front wheel bearing. Tie rod was a piece of cake. Had to go back to get a 35mm deep well for the drivers side axle nut. For the life of me it will not budge. I've soaked it in nut blaster. I have about a 2' breaker bar on it. Beat the hell out of it with the rubber mallet. Even stood on the end of the breaker bar. I'm thinking it has red loctite on it as the nut blaster is tinted red after a few sprays. Any suggestions? I'm thinking I may have to take this one to the mechanic with his impact wrench. Thanks!
    Sent from my DROID RAZR using Tapatalk
    2009.1 Liquid Red G8 GT
    2001 Grand Prix GT Bright Red
  2. #2 Re: Can't break free front axle nut.
    Longer breaker bar, or impact the **** out of it.
  3. #3 Re: Can't break free front axle nut.
    Or if you are feeling daring you could put the breaker bar and socket on the nut then drive the car forward slowly and it'll break it free
    Toledo, Ohio
    Lol, the deep wheel socket doesn't fit through the wheel cap opening.
    Heading to Lowes to find a length of pipe.
  5. #5 Re: Can't break free front axle nut.
    Jun 2011
    Detroit, MI
    Sawzall.
    iLoveSpade
  6. #6 Re: Can't break free front axle nut.
    Waukesha, WI
    a little heat on the nut
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  7. #7 Re: Can't break free front axle nut.
    GTX Level Member Steel Armadillo's Avatar
    Orlando, Florida, United States
    Are you replacing the hub? If so, heat the shizz out of it with a Oxy/Acetelyne torch, or propane if that's what you have available (Oxy is hotter/better), then spin that beast, it will walk off for you.lol
    If you can't/wont do that, get an impact wrench, it'll come off.
    Just a word to the wise, an impact is one of the most important tools you can own, FWIW...
    The evil LG8 still refuses to die.
  8. #8 Re: Can't break free front axle nut.
    put the spare tire on, then you can get to the nut, and get a 4 foot pipe that fits your breaker bar, it will come off, leave the car on the ground and unbolt it.
  9. #9 Re: Can't break free front axle nut.
    SWPA
    Get bigger balls and more muscles, although I will say I once picked a car up off the ground by the breaker bar/cheater pipe, because someone WAY overtightened it.
  10. #10 Re: Can't break free front axle nut.
    GT Level Member 98GPGT2D's Avatar
    Ontario, Canada
    Find a buddy who has an Electric Impact gun with at least 300ft/lbs break away torque. Should be enough to rattle it loose. Makita makes a decent plug in electric 1/2 impact.
    Jay
    2005 GMC Jimmy 4x4 2-door 5-speed. CompCams 266HR Cam, W4M tune, 2.5" Exh, 246,000Kms (Sept 2012) Daily Driver.
    2002 Yamaha YZ125, Summer Toy.
    1997 GrandPrix GT 4 door White Ext, Pleather Int. 255,000Kms GF's Daily Driver.
  11. #11 Re: Can't break free front axle nut.
    Toledo, Ohio
    4' cheater bar did the trick!! It was starting to bend a little....then broke free! New wheel bearing is in!! I killed the battery by leaving the ignition on, so i have to charge it before taking it for a ride. Hopefully its much quieter. Fairly simple job with the right tools.
  12. #12 Re: Can't break free front axle nut.
    make sure you torqued the new wheel bearing to 118 ft lbs. (axle nut)
    Toledo, Ohio
    Thanks, yeah I think I torgued it to about 120.
  14. #14 Re: Can't break free front axle nut.
    Toledo, Ohio
    All that work and still have the damn front end humming noise. I swear it sounds like its coming from the drivers side front. No noise when in park and moving stearing wheel back and forth. Only seems to increase with speed. Reminds me of my 1st car when i'd put snow tires on the rears...at higher speeds they had a hum to them. Any ideas? Thanks!!
  15. #15 Re: Can't break free front axle nut.
    does the sound go away when you turn a certain way?
    Because say the sound goes away when you turn left, that means the right wheel bearing is bad.
    And tires can make noise tooo, what brand of tires are they?
  16. #16 Re: Can't break free front axle nut.
    GT Level Member 04BlackComp_G's Avatar
    Apr 2008
    Rockport, ME
    When I replaced mine front bearing I did both just so I had that peace of mind. While you're doing all that work might as well do it all around to ensure there are no issues.
    2009 G8 GT #1311 of 1949:CTS-V front/Camaro rear brakes, Solo Performance axle back exhaust
    2006 GP GXP: ZZP catback, k&n intake, retrofit headlights, cts-v brakes
    2007 Escalade ESV:family hauler
  17. #17 Re: Can't break free front axle nut.
    Toledo, Ohio
    Yeah, I plan on doing the other one too. Actually the sound seems to go away when turning right....hard to tell because the sound deminishes at slower speeds.
    The tires are Goodyear Eagle T/R's. Car has 55,000 miles and i'm thinking this is the 2nd set of tires. Still decent tread left on the fronts. I just recently rotated them.
    I plan on putting it up on jack stands when i get home from work Tuesday....and letting it run to see if it still hums....this would eliminate the tires as an issue.
  18. #18 Re: Can't break free front axle nut.
    Jun 2011
    Detroit, MI
    have the wheels been balanced and aligned recently? just a thought.
    iLoveSpade
  19. #19 Re: Can't break free front axle nut.
    SWPA
    Quote Originally Posted by Hippo Machine View Post
    Neither one of those issues would cause a rubbing noise.
  20. #20 Re: Can't break free front axle nut.
    Jun 2011
    Detroit, MI
    humming noise can be a balancing issue
    iLoveSpade
  1. What did i break?
    By NR92 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-22-2011, 08:30 PM
  2. Break in oil
    By Stu in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-19-2009, 10:22 PM
