Thread: DIC Issue
Results 1 to 7 of 7
  1. #1 DIC Issue
    Dec 2011
    Illinois
    Hi Guys. I have a 2000 GTP. When I shut off the car (Key off) my DIC resets everything to zero. The only part that remains the same is the oil life index. That seems to maintain when I shut off the vehicle. Any ideas? Thanks in advance!
  2. #2 Re: DIC Issue
    GT Level Member Haulero's Avatar
    Gray Court, South Carolina. USA
    ...... That is normal?? My car does the same, reset everything but oil life. I doesn't do it right after I turn the key off, it takes a few seconds tho
  3. #3 Re: DIC Issue
    Dec 2011
    Illinois
    Exactly. Mine is doing the same thing. It didn't always do that. It should maintain until it is reset by the user.
  4. #4 Re: DIC Issue
    Isn't everything supposed to reset when you turn the key off? cause mine always do and I tho that was normal (except oil life)
  5. #5 Re: DIC Issue
    Dec 2011
    Illinois
    No, it's not normal. Only when you go to the specific mode and hold "Reset" is it supposed to zero out.
    RamAir - I checked fuses already. I'll have to look into the constant power source and see if there's something going on there....
  6. #6 Re: DIC Issue
    It doesn't matter anyway, doesn't bother me at all
  7. #7 Re: DIC Issue
    GTP Level Member mrlogic1234's Avatar
    Jul 2010
    Detroit
    Defiately not normal. Mine doesn't clear untill I press and hold reset. It would suck if it did, because my fuel guage is not working properly. Wickedly innacurate.
    Ryan
    2000 GTP Coupe Green/Grey - SOLD!
    2008 GXP Black/Ebony
  1. 97 GTP issue w inside Fan/Blower issue
    By JoeRappa in forum General Tech Discussion
    Last Post: 10-03-2011, 10:16 PM
  2. Fog HID Issue
    By tucker98 in forum 04+ Specifics
    Last Post: 11-14-2010, 12:20 AM
  3. PCM issue?
    By ill12will8 in forum General Tech Discussion
    Last Post: 10-03-2010, 12:06 PM
  4. MAF Issue
    By prostallion347 in forum General Tech Discussion
    Last Post: 03-30-2010, 11:36 AM
  5. RPM Issue
    By abuckley1290 in forum General Tech Discussion
    Last Post: 05-19-2009, 01:32 PM
