Thread: Can't break free front axle nut.
Results 1 to 20 of 82
  1. #1 Re: Can't break free front axle nut.
    Goodyears = problem
    but anyway, check that other side and see whats up.
  2. #2 Re: Can't break free front axle nut.
    SWPA
    Quote Originally Posted by Hippo Machine View Post
    First, I said just a thought.
    Second, yes it can.
    Third, if you don't have anything to say that would help the OP then get out.
    First, you're wrong
    Second, no it can't
    Third, I posted advice earlier
    Quote Originally Posted by 04BlackComp_G View Post
    When my wheels were out of alignment I had horrible vibration and A HUGE HUMMING NOISE. So yes they can make that noise. And also my friend's truck hums because of the tire tread so essentially anything can cause it. We are here to help people as hippo said. Man, oh man cccc ccan't we all jj-jut get along?
    Sorry, but your bad alignment didn't cause the humming, something else did. I had my Stealth WAY out of alignment from having the front end apart several times and never once had a humming noise.
  3. #3 Re: Can't break free front axle nut.
    GT Level Member 04BlackComp_G's Avatar
    Apr 2008
    Rockport, ME
    First, you're wrong
    Second, no it can't
    So you want to sit in my car and I re-create the issue and you tell me otherwise? You weren't there to experience it so don't call on something that YOU don't know about. My ears and my ass know what I heard and felt and when I put the stockers back on it solved the problem. Every car is different pal. But then again, I'm a dumb ass and absolutely no clue what I'm talking about.
    2009 G8 GT #1311 of 1949:CTS-V front/Camaro rear brakes, Solo Performance axle back exhaust
    2006 GP GXP: ZZP catback, k&n intake, retrofit headlights, cts-v brakes
    2007 Escalade ESV:family hauler
  4. #4 Re: Can't break free front axle nut.
    SWPA
    Out of BALANCE wheels can cause vibration, anyone with half a brain knows that, but a bad alignment will NOT cause a humming noise. There is a difference between vibration and humming.
  5. #5 Re: Can't break free front axle nut.
    Jun 2011
    Detroit, MI
    First, you're wrong
    Second, no it can't
    Saying to get bigger balls and muscles is not relevant advice..
    Just because your Stealth never hummed from alignment, doesn't mean someone else cant. Stop being an ass.
    iLoveSpade
  6. #6 Re: Can't break free front axle nut.
    SWPA
    You obivously didn't read because I did mention that sometimes they are overly tight since I did lift a car once from an over-tight axle nut. And my car was SEVERELY out of alignment and didn't hum. I have driven several cars that were out of alignment and not one of them hummed. There is nothing to cause a humming noise when its out of alignment so NO it wont cause a hum. I've been working on cars since before you were born so I think I know a little more than you.
  1. What did i break?
    By NR92 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-22-2011, 08:30 PM
  2. Break in oil
    By Stu in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-19-2009, 10:22 PM
