Thread: Disable key remote light flash for lock/unlock...
Results 1 to 5 of 5
  1. #1 Disable key remote light flash for lock/unlock...
    Jan 2012
    US
    Not sure which section to put this in...but anyways...
    I have a 2002 Grand Prix GT.
    I've read that you need to pull the Mall PGM fuse, put the key to ACC, etc. But I can't find the Mall PGM fuse. My car has the underhood fuse box and when I look in the manual for that particular fuse, it's just not listed. I also don't want to rewire to the parking lights, I just want to disable the feature but I can't seem to locate the Mall PGM fuse. Any help? Thanks
  2. #2 Re: Disable key remote light flash for lock/unlock...
    Oct 2011
    That fuse is located in the fuse box inside of the car. Open the glove box, fuse access will be on the right, and it should be labled either on the fuse access door, or the fuse block itself.
  3. #3 Re: Disable key remote light flash for lock/unlock...
    Jan 2012
    US
    Quote Originally Posted by 03GPRIXGT View Post
    Yeah I found it and got it programmed correctly so I don't shorten the life of my HIDs. Thanks!
  4. #4 Re: Disable key remote light flash for lock/unlock...
    Apr 2012
    michigan
    i'v been looking for the fuse and i can't find it, also i do not know what program to run in. any help would be appreciated, thanks!
    Ohio
    Read the manual.. It tells you what to do..
    Pop open the glove box, pull the plastic piece out on the right side. Look in at the fuse panel and it will be on the far right in the middle.
  1. Replies: 10
    Last Post: 08-16-2011, 08:36 AM
  2. Replies: 1
    Last Post: 03-14-2011, 10:05 PM
  3. Disabling light flash on lock/unlock
    By Wingsfreak9 in forum Audio, Security & Visual Electronics
    Last Post: 08-06-2010, 01:30 PM
  4. Repeated TCC lock/unlock with no PCS readout
    By DanGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-18-2010, 11:02 AM
  5. remote door lock horn only when lock ?
    By NEONNIGHT34609 in forum General Tech Discussion
    Last Post: 12-10-2008, 09:05 PM
