Thread: Does air intake filter size actually matter?
Results 1 to 6 of 6
  1. #1 Does air intake filter size actually matter?
    GT Level Member GTLGDP's Avatar
    Oct 2011
    New Jersey
    Mine is 9" right now, but it's shot and i'm gonna remove the tubing to it and just put it on the throttle body, but a 9" filter wont fit right. So, i was thinking about just getting like a 4 inch filter and slapping it on there. Would there be any difference? I feel like 9 inches is unnecessary for a filter.
  2. #2 Re: Does air intake filter size actually matter?
    I live here. TLSheff's Avatar
    If your modded to the extreme I think the difference would still be miniscule. Stock just do it. People tend to run the 4" in the FWI because it fits better and doesn't require cutting so much, but if your just running off the TB most go for the 9"
    I don't think it'd make a difference, just looks better
  3. #3 Re: Does air intake filter size actually matter?
    Quote Originally Posted by GTLGDP View Post
    Remove dog bones.
    Let engine rock forward.
    Bolt filter to TB.
    Push engine back and bolt dog bones back on.
    There, 9" filter on the TB...how's that?
  4. #4 Re: Does air intake filter size actually matter?
    Feb 2009
    flintnasty MI
    The bigger the better....
    Most everyones GTP can flow about 400cfm of air without issue... It takes a big filter to be rated at 600cfm... and that is assuming a fairly large restriction.
    Technically if you can run a giant filter, you will be really close your engine thinking you dont have a filter on there.. but it will take alot of filter to do so.
    With our 600+cfm turbo stuff, we could see 30-40-50whp just from taking our fairly huge filters off and going to no filter.
  5. #5 Re: Does air intake filter size actually matter?
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    you wouldnt know the cfm of 3'' and 4'' piping would you? just really wondering if i should go 4'' but im not gonna waste the money if my car isnt restricted by my 3'' piping. im N/A
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  6. #6 Re: Does air intake filter size actually matter?
    woot oversized filters.
    Depends on the vacuum.
    http://www.zzperformance.com/blog/in...-and-theories/
    Because vacuum affects flow so much, it makes head flow numbers seem quite hilarious.
  1. Which size air intake filter do i need?
    By GTLGDP in forum General Tech Discussion
    Last Post: 11-24-2011, 03:27 PM
  2. intake filter question
    By mcsddd in forum General Tech Discussion
    Last Post: 08-23-2010, 06:22 PM
  3. cone filter size
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-12-2009, 12:51 AM
  4. what size wrenches for fuel filter on a 02 GTP?
    By shaferz in forum General Tech Discussion
    Last Post: 05-27-2009, 12:57 PM
  5. what size filter for the wizard CAI
    By 99prixgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-17-2008, 01:21 AM
