Transmission Cooler would be a good investment for the stock transmission. My Lincoln Continental has a tranny that is also notorious for failing but i'm at 102k miles with no issues so far *knock on bird's eye maple*.
Personally I would go for a 97-03 gtp. Try to get a special edition one. Something you dont see everyday. I like the gxps to but with a gtp you have to work to make it your own and with a gxp they already come with 300hp lol. Yes gtps do have there problems but dosnt any car as I see you guys already talking about tranny setups/changes. just my 2 cents.
i read a post on another website that said a cooler wont help the transmission any because its not a heat issue, its just a matter of parts breaking. And I wanna try and make this car last as my dd for the foreseeable future, so a newer car has more appeal. ive thought about a newer compg but the v8 really appeals to me. anyone owned both? or had extensive experience with both?
04 and 05 were the only years for comp g's. And the none of the tranny failures are due to heat. Imo a tranny cooler is just another place to leak.
3800 tranny failures yes, i'd agree.
But LS4 tranny failures, i'm not so sure.
Its the same trans as the comp g more or less. And according to all the failures I've read, there all parts issues
chains, input shafts, solenoids, worn clutch packs?
These trannys run hot how it is.... a cooler has one benefit with more potential negative benefits. If you want to go fast... GTP w/ mods. Then you can get into a reliability issue in going that route. The GXP like Chris said is fun straight out of the box. Aftermarket for the GXP is scarce and all come with a hefty pricetag. One of the bigger concerns with the GXP is people complain of large oil usage. Reason for this is when DoD is initiated, the inactive cylinders are still getting oil to them. When DoD disengages, it burns the oil. Best way to get around this... get it tuned out. People who had DoD tuned out said they barely lost any fuel mileage, maybe 1-2 mpg.
then its time for a cam..........
smooth means the shift is taking longer.
as stated, there are GM bulletins out for significant oil usage on the 5.3's with active fuel management. the fix should be covered by GM, and it involves a cover of some sort over the oil control manifold. i think they still have a special policy on it anyways... fuel saving with active fuel management (the department of defense didn't like the term DOD, and made GM change it lol) was from 10-20%, which comes out to 2-4mpg. honestly, i've driven a few trucks with AFM, and it almost never turned the cylinders off, and when it did, i definitely noticed power loss and it took too long to switch back for my taste.
To the OP, GXP w/ a tune and a rear mount turbo. You're welcome.![]()
really? huh. i know the shop i work at has at least worked on a gxp for the same issue. they ended up putting a new engine in it, it might have still been under warranty
