Thread: O2 Sensor
Results 1 to 10 of 10
  1. #1 O2 Sensor
    Dec 2011
    Anoka, Minnesota, United States
    I need to replace my O2 Sensors to clear the Check Engine Light...any suggestions on which O2 Sensor(s) to purchase to save $$ but ensure quality?
  2. #2 Re: O2 Sensor
    stock replacements
    denso/delco
  3. #3 Re: O2 Sensor
    Pennsylvania
    The front O2 (the one by your spark plugs) is the one that will make decisions on how the engine runs. Stock replacement is best. I'd bet that this is the one that set your light, so replacing it before purchasing the other sensor could save you money. The rear one after the cat is just there to make sure you have a cat. I wonder if you could get away with a cheaper sensor back there... anyone know?
  4. #4 Re: O2 Sensor
    GTP Level Member
    Oct 2011
    Raleigh, NC
    How do you know it is the O2 sensors ? What code are you getting ?
    1997 Red GTP 182000 miles stock
  5. #5 Re: O2 Sensor
    MO
    Quote Originally Posted by SlowNA06 View Post
    The front O2 .
    Gotta be about one of the stupidest statements I've seen on here. Saving money.... why not pull the engine code and have it tell you WHICH sensor needs to be replaced? That way instead of guessing in order to save money you actually figure it out to save money...
    <brandonl2000> LMAO D!!
  6. #6 Re: O2 Sensor
    Pennsylvania
    Totally inaccurate.
    I've said dumber things on here.
  7. #7 Re: O2 Sensor
    MO
    Totally inaccurate.
    Maybe so, but my spam filter tends to catch that
  8. #8 Re: O2 Sensor
    utah
    i have a few stock delco sensors for sale...lemme know i ya need one
  9. #9 Re: O2 Sensor
    I agree with knowing the codes to know what is actually going on. I've seen a lot of guys replace an O2 with a P0171 code. All they did was throw money away because that code is 99% never about the sensor.
  10. #10 Re: O2 Sensor
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Exactly, Bill saved me the cost of an o2 , I had a P0171 and through his posts ( and Falconjohn's ) I managed to finally fix it.
    It was the egr tube at the manifold had a small crack. I also replaced the missing throttle body screen, at the same time.
    Bill - Thank you for the help and patience.
  1. thermostat temp sensor and interior air temp sensor failure?
    By lewethetiger73 in forum General Tech Discussion
    Last Post: 11-26-2011, 10:07 PM
  2. question about low coolant sensor,fuel level sensor,and the
    By spider4 in forum General Tech Discussion
    Last Post: 11-26-2011, 09:19 AM
  3. Best way to change O2 sensor/ECT sensor?
    By 99gtxws6 in forum General Tech Discussion
    Last Post: 11-23-2010, 09:36 AM
  4. camshaft sensor or crank sensor?
    By Viper in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-06-2010, 04:43 PM
  5. Picture request of Coolant Temp Sensor and TPS sensor parts
    By David A Smith in forum Shops and Community Heroes
    Last Post: 06-11-2010, 11:05 AM
