Thread: gas mileage
Page 17 of 38 FirstFirst ... 7151617181927 ... LastLast
Results 321 to 340 of 755
  1. #321 Re: gas mileage
    Feb 2013
    Columbus, Ohio
    My 98 GTP is getting 27 highway, and about 20 city with 198k on it, and my 08 GXP is getting about 21 Highway (kind of a stretch) and City is about 16.
    My Grand Prix Current and Past, 08 Grand Prix GXP, 04 Grand Prix GTP, 98 Grand Prix GTP, 02 Grand Prix GTP, 98 Grand Prix GT, 89 Grand Prix SE
  2. #322 Re: gas mileage
    SE Level Member harner's Avatar
    Apr 2012
    New Ringgold, PA
    I've been getting about 19-20MPG consistently in my '98 GT since I now had OD again. 20MPG is with more highway than normal. Not too impressive, but cheaper than my TBSS and I can run 87.
    1998 Grand Prix GT Sedan - SOLD
    10 Camaro 2SS/RS | 94 TA | 87 IROC | 06 Silverado 1500
  3. #323 Re: gas mileage
    GTP Level Member joe0813's Avatar
    Boston, MA
    my mpg sucks.... i only get 12 what the hell
  4. #324 Re: gas mileage
    SE Level Member Kikasscuda's Avatar
    Feb 2013
    New York
    my mpg also sucks, i get approx 17.7 mpg, and if the specs of my car are right and i have a 18 gallon tank, when 13.5 gallons are used its on the line of E, i also dont have overdrive so it only goes up to 3rd gear which is a gas killer, thankyou GM for not making our 4th gearclutch hardened, we're reaping the benefits of our 4th gear splines after 120k
  5. #325 Re: gas mileage
    Feb 2013
    Benton,IL
    Right now, I'm sitting at 320 with still a bit over 1/4 tank left. Lately its been getting really good MPG's. I can normally get 23-24 (27+ pure highway) out of it doing mostly rural driving. And I'm pretty light on the pedal. Overall, your numbers are very close to my GT's.
    I did run some sea foam thru just the gas tank and it did seem to help a little bit.
    I'm right along with you Danielle, that's one of the reasons I joined, to get an idea if what I'm getting is close to average or possibly better. Pleased to meet you all!
    Vejita88
  6. #326 Re: gas mileage
    Dec 2012
    Illinois
    I've been average 15 or so on the DIC all city in my 2002 GTP. While it has been reasonably cold, should I be checking for problems? Or is this par for the course?
  7. #327 Re: gas mileage
    I wouldnt worry.
    I just hit 125 miles on this tank, already used 10.8 gallons and just hit the 1/4th tank mark. I drive all city, less than 7-8 miles most days. I bet I waste half my tank from idle time.
  8. #328 Re: gas mileage
    Sep 2012
    Miami
    so i have an '04 GTP. Only Modifications I've done are a k&n Air Filter and my brother put in a Vortex semi circle spiky contraption (sorry i dont know what its called anymore it was 5 years ago) in the air tube that feeds the engine. As far as gas mileage goes my car does amazing on highways i can drive from Miami to Orlando in about 3/4 of a tank. If i remember the last time i ran a trip meter on the DIC it was about 300. However in this godforsaken city im getting about 13 - 14 MPG with a light foot. Sometimes less if i drive a bit harder. Is there anything i can do to improve that?
  9. #329 Re: gas mileage
    Remove vortex thingy for one.
    Clean your throttle body and MAF sensor with the correct cleaners, new OEM spark plugs could help if it needs them.
  10. #330 Re: gas mileage
    I live here. DirtDog's Avatar
    Jun 2012
    What exactly are the point of the those vortex things?
  11. #331 Re: gas mileage
    Sep 2012
    Miami
  12. #332 Re: gas mileage
    Read.
    04 Comp G.
  13. #333 Re: gas mileage
    Sep 2012
    Miami
    sorry for double post not sure why it did that. My brother said that its supposed to improve hp and mpg. throttle body has been cleaned recently and not sure what a maf sensor is sorry im not exactly car savvy. i know some stuff but not everything and usually anything i have to do to it, i take it somewhere to get it done. i havent had any check engine lights yet so not sure about spark plugs so far i have 56k miles approx.
  14. #334 Re: gas mileage
    SE Level Member Comanche1959's Avatar
    Nov 2010
    Kentucky
    I changed my plugs / wires and am only getting 22.9 mpg highway. Used to be higher...I posted 21.3 above, but meant 23.1. Mileage has been dropping about a tenth of a mpg at a time over a few months. Wonder why the slow decline, even after new plugs & wires?
    Steve
  15. #335 Re: gas mileage
    Quote Originally Posted by Comanche1959 View Post
    Steve
    Might be another issue. Depending on age of the car it might need somthing else. Could be a o2 sensor or the cat converter giving bad readings to the rear o2 causing more fuel to be burned. Drive the speed limit or under and increase mpg by alot aswell. Its truely hard to figure it out over the internet.
  16. #336 Re: gas mileage
    Florida
    I see why its not suggested to run AL104s on stock pulley and tune cuz my mileage has taken a noticable hit. Im getting around 20-30 less miles per tank compared to my older plugs. Hopefully it picks back up once im tuned otherwise might just get a fresh 605 plug along with the other ones i have and swap those in.
  17. #337 Re: gas mileage
    Dec 2012
    Illinois
    I wouldnt worry.
    Cool. I'm about the same range with an additional trip to and from the gym most days. It's decent on the highway. Driving from Chicago I want to say I was around 24. I didn't buy a supercharged car and expect awesome gas mileage.
  18. #338 Re: gas mileage
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    Keep it under 2k rpms when maintaining speed.
    And hit the catalytic converter when it's cold, any rattle means you should replace it
  19. #339 Re: gas mileage
    Nov 2010
    Kentucky
    I drive the speed limit on my daily commute of only 11 miles one way over rolling country. May try the O2 sensor.....easy enough to do.
    Thanks,
    Steve
  20. #340 Re: gas mileage
    Jan 2013
    michigan
    i'm right around 23mpg right now which is up from the 17 or so that i was getting a few weeks ago
  1. Gas mileage
    By Zyrebel in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-17-2010, 01:02 PM
  2. 04+ S/C gas mileage
    By carl06GT in forum 04+ Specifics
    Last Post: 08-30-2010, 08:17 AM
  3. Why am I getting bad Gas Mileage?
    By JDCMoney in forum General Tech Discussion
    Last Post: 06-10-2010, 01:34 PM
  4. What can I do to get better gas mileage?
    By isucyclones3 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-19-2009, 11:58 PM
  5. Gas Mileage
    By TCO in forum Off Topic Discussion
    Last Post: 05-07-2008, 11:01 AM
