Thread: gas mileage
Page 14 of 38 FirstFirst ... 4121314151624 ... LastLast
Results 261 to 280 of 755
  1. #261 Re: gas mileage
    GT Level Member BrendanMurphy's Avatar
    Jan 2012
    Keswick, Ontario
    Found out my crappy mileage was caused by the vac line on the fuel regulator being unplugged..... Noticed on torque that the vacuum was sitting at 18 found the line put it back on and went back to 21
    Derp RALM's Avatar
    Aug 2012
    Brandon, South Dakota
    Quote Originally Posted by Dee23 View Post
    Yes, vacuum leaks can interfere with getting optimum MPG. Vac leaks arent monitored, so the MAF,IAT,IAC, arent reading that extra amount of air so the meterization gets thrown off and also it can be dirty air depending on how bad the leak is bc its not being filtered either by your air filter.
    If i can remember right, I think the Vac PSI should be around 19-22psi but if u do manage to get the VAC gauge just hook it up to the brake booster line. For a easy quick check, use CARB cleaner and spray on all the VAC lines and listen for the change of the idle.
    Come to think of it I need to check and probably clean my air filter. Just changed it about six months ago but I drive a dirt road on a normal basis
    1995 Grand Prix SE 3.1L V6 N/A
    216,000 Miles
    1998 Grand Prix GT 3.8L V6 N/A 211,000 Miles (RIP)
  3. #263 Re: gas mileage
    GTP Level Member
    springfield IL
    Im at 23 + in town driving... :-). Not bad for 2000 GT 136,xxx miles
  4. #264 Re: gas mileage
    GT Level Member Jtiger360's Avatar
    Nov 2012
    United States
    I have no ideal. All i know is I fill my tank once and I do not have to get more gas for over 3 weeks and that is on a 3800 v6
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    Burned about a half a tank in 4 days with less than 100 miles since it was full...
    Racekar?
    Or P.O.S?
  6. #266 Re: gas mileage
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Quote Originally Posted by Jtiger360 View Post
    You proly only drive 15 miles a day.
    How many miles since your last oil change ?
    1997 Red GTP 182000 miles stock
  7. #267 Re: gas mileage
    Nov 2012
    Ohio
    3800 II V6 here. 24-26 mpg range. 30miles everyday through nothing but flat farm country. Burns about $45/week worth of gas. I don't always fill it either.........damn oil prices.
  8. #268 Re: gas mileage
    Out West
    got 13mpg city today lol...
    Whine with your Cheese?
  9. #269 Re: gas mileage
    Donating Users Jordan's Avatar
    Oct 2011
    Richland Center, WI
    Drove 60 miles to Madison today, drove around there for a while, and by the time I got back I think I averaged about 25. Forgot to check when I got home, but it was 24.5 half way back.
    2009 Cobalt SS/TC Coupe |
    Summit White | 131k | ZZP charge pipes, ZZP heat exchanger, ZZP 3" downpipe, HP tuned, Muffler delete, K&N Typhoon intake, dual interceptors, retrofits with switchback halos
    2006 Grand Prix GXP | Black | 95k
  10. #270 Re: gas mileage
    Florida
    Consistently getting 300-330miles on a full tank doing city driving only.This car even with boost is not bad on gas but its when i get on it and can just watch that needle drop thruout the day lol.
  11. #271 Re: gas mileage
    i got my average up to 16 today driving around town, lots of stop and go. this is since the lim job and new vac lines, it never went higher then 14 tops before.
    2 new o2 sensors may get it back to 18-20 around town???????
  12. #272 Re: gas mileage
    Maybe?
    I only get 14-15 city in this colder weather. Though my daily miles is normally only 5-6 miles.
  13. #273 Re: gas mileage
    GTP Level Member L36 Killer's Avatar
    Jul 2012
    Harrisburg, Pennsylvania, United States
    getting btwn 19 and 20 MPH highway...
    "SHELLY" GRAND PRIX GT 02. SLP HEADERS & EXHAUST, K&N CAI, BMR REAR SUSPENSION AND STRUT BRACES, 180 T-STAT, AGX STRUTS, EIBACH SPRINGS, OVERKILL PCM, YELLA TERRA 1.7 ROCKERS, GT1 CAM, SEXMAN PORTED & POLISHED HEADS, STAGE 2 PORTED TB
  14. #274 Re: gas mileage
    Mar 2012
    NC
    Quote Originally Posted by bayus2972 View Post
    I thought you said it was higher?
  15. #275 Re: gas mileage
    14 is the high side of around town, most of the time, (i was getting before the lim job) 10 to 12 was the norm. now if it drops to 12 it comes back up to 15/16. it never did that before.
    and ive read a list someone posted that o2 only last for 60, or 80,000 miles, ( dont know how true that is) i got 225,000 almost and no service records but my own. figure it cant hurt.
  16. #276 Re: gas mileage
    Aug 2012
    SE Wisconsin
    Last tank I averaged 24.5mpg calculated (DIC read 25), mixed city highway.
    Over summer I was commuting to downtown milwaukee averaging 55-75. Calculated 28. DIC read 32-33 from the time I left my garage, till the time I parked at work.
  17. #277 Re: gas mileage
    Nov 2012
    United States
    Quote Originally Posted by GTP in RTP View Post
    I drive about 2-4 miles a day. I am getting an oil chnage next month. I just bought the car a month ago and I have no idea when it was last changed. The change oil light has not turned on yet.
  18. #278 Re: gas mileage
    SE Level Member Comanche1959's Avatar
    Nov 2010
    Kentucky
    2001 Grand Prix 3.8GTP getting 23.4 average country driving. Has always been in that range. Dunno what range is, but when I fill the tank it shows 370 or so miles.
    Steve
  19. #279 Re: gas mileage
    Aug 2012
    RI
    99 buick regal gs with my speed sensor bad, I get about 21-22 driving between 35-55 mph work and back. I have yet to do an accurate test for highway but the computer dances between 27-33 mpg on instant mileage driving between 65-75mph
  20. #280 Re: gas mileage
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    I get around 400 - 450 miles per tank if I do straight highway driving, but that's non stop =P
    if I drive highway with stops and what not, I can get probably 350 - 390 miles.
    City, I get probably around 250 - 310 miles per tank give or take
  1. Gas mileage
    By Zyrebel in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-17-2010, 01:02 PM
  2. 04+ S/C gas mileage
    By carl06GT in forum 04+ Specifics
    Last Post: 08-30-2010, 08:17 AM
  3. Why am I getting bad Gas Mileage?
    By JDCMoney in forum General Tech Discussion
    Last Post: 06-10-2010, 01:34 PM
  4. What can I do to get better gas mileage?
    By isucyclones3 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-19-2009, 11:58 PM
  5. Gas Mileage
    By TCO in forum Off Topic Discussion
    Last Post: 05-07-2008, 11:01 AM
