Thread: 2002 GP gas tank sending unit, replacing
Results 1 to 3 of 3
  1. #1 2002 GP gas tank sending unit, replacing
    Feb 2016
    North Carolina
    Is the gas tank sending unit part of the fuel pump on a 2002 GP? The car has a 3.8 L engine.
    If so, do you have to replace the entire thing (fuel pump & sending unit) to fix a gas gauge not reading correctly.
    I am being told the sending unit is bad, but the entire unit (pump and sending unit) have to be replaced as one unit, is this correct?
  2. #2 Re: 2002 GP gas tank sending unit, replacing
    Mar 2014
    Tucson
    Nah. You can replace just the level sensor. The clips and wire connections can be a little fiddly, but it's very doable. Some guys will say to just replace the pump since you're right there, but considering these cars have an access hole, I'd roll the dice. It's not like you have to drop the tank.
  3. #3 Re: 2002 GP gas tank sending unit, replacing
    Aug 2021
    Texas
    had same issue w fuel gauge not correct for YEARS,
    then the fuel pump went last summer.
    replaced pump
    it also ​fixed the gauge
  1. 2002 Grand Prix GT fuel sending unit question?
    By Der2z in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-17-2012, 11:10 AM
  2. oil pressure sending unit?
    By beaver75 in forum General Tech Discussion
    Last Post: 03-29-2011, 10:04 PM
  3. Oil Sending Unit
    By TeeWX in forum General Tech Discussion
    Last Post: 03-20-2010, 12:31 PM
  4. where to put oil psi sending unit???
    By ERDGT1 in forum General Tech Discussion
    Last Post: 02-01-2010, 09:30 PM
