Thread: 2004 Grand Prix Charging issues
Results 1 to 6 of 6
  1. #1 2004 Grand Prix Charging issues
    Aug 2021
    Texas
    3.8 L non-supercharged
    Recently my car has had issues turning ON.
    I only hear the clicks it makes when battery is LOW. So I jump start it and starts fine. I?ve replaced the alternator and it still doing it, Battery is a year-ish old. I?m still getting 12 volts on the meter.
    Terminals are clean. Fuses are ok.
    Any tips would be greatly appreciated.
  2. #2 Re: 2004 Grand Prix Charging issues
    St. Louis
    Keep the meter on it and have someone try and start it. Note what the meter reads. Could have a bad battery.
    Are the gounds clean? Check the one at the transmission bellhousing as well. Cables tight?
  3. #3 Re: 2004 Grand Prix Charging issues
    Aug 2021
    Texas
    So I checked two ground wires coming from the transmission, almost right in front of the driver side radiator fan. Cleaned them both. But noticed something.
    I charged the battery to about 13.84 volts and about 10 minutes later it went down to 11.83 Volts.
    But after the 3rd crank the engine started normal and was getting a reading of 14.98 volts exactly while ON.
    So now I have the terminals disconected and waiting to see the final reading on my multimeter.
    I know I?m suppose to have 12vokts at least
  4. #4 Re: 2004 Grand Prix Charging issues
    Aug 2021
    Texas
    Yeah, I?m getting a constant/steady 10.83volts on my battery with the meter.
    Even after I turned it OFF after I jumped started it.
  5. #5 Re: 2004 Grand Prix Charging issues
    St. Louis
    That's really low for a resting charge, almost dead. Would likely not start it. I would find a way to slow charge it (3amp until full) and then stick it back in and see what you get. If it starts without a jump, then keep an eye on it and see if it drops again. If it does, then you either have a bad battery or a parasitic draw in the system somewhere.
    The EEC and stereo memory voltages are not enough to draw a healthy battery to 10V overnight. There are how-to videos explaining how to check for parasitic draw using a meter between the battery cables and the charging system.
  6. #6 Re: 2004 Grand Prix Charging issues
    Apr 2014
    commerce twp,mi
    im thinking that after a slow charge, a load test would be wise
    08 grand prix NA3800
  1. 2004 grand prix charging system failure
    By Mrvork in forum General Grand Prix Discussion
    Last Post: 08-15-2022, 10:52 PM
  2. starting issues 2004 grand prix
    By Jagr in forum Introductions/Noob Questions
    Last Post: 11-09-2016, 06:32 PM
  3. 2004 Grand Prix GTP Supercharged Issues
    By pitt23fan in forum General Tech Discussion
    Last Post: 05-11-2016, 09:13 PM
  4. Starting issues will 2004 Grand Prix GT
    By Benjamin02 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-20-2014, 07:20 PM
  5. 2004 Grand Prix Gt electrical issues
    By hydrashock in forum General Tech Discussion
    Last Post: 03-18-2013, 02:06 PM
