Thread: Door handle removal
Results 1 to 6 of 6
  1. #1 Door handle removal
    Canada
    I need to get all four door handles removed so that I can paint. I have had the front passenger handle off in the past but I am working on the front drivers side handle. I have one clip open but there does not appear to be a second. Can anyone shed some light or provide some pointers?
    Thanks.
    '01 Grand Prix GTP Special Edition
    Trying to stay pretty close to stock now. Just a few bolt-ons for fun.
    Trying to keep it alive, pretty, and fun.
  2. #2 Re: Door handle removal
    St. Louis
    Not much came up but this is an excerpt from a write-up on swapping in some other type of handle.
    8. now remove the two 10mm bolts holding in the door handle
    9. now carefully remove the door handle from the car until the rods prevent it from coming out any farther
    10. now follow the handle rod down till you find the locking clip, it's black and a though bugger, but a little brute force and it'll pop open
    11. now take a razor blade and break off the locking tabs (do this now for the rear handles as well
  3. #3 Re: Door handle removal
    Canada
    Thanks, FordMan. The first few steps I have been able to accomplish. That last one I do not understand.
    I have had the passenger's handle off a few years ago and remember it being tricky but just a matter of twisting it the right way.
    This time I started with the driver's door and have one of the rods disconnected but the one for the lock is where I am stuck. It is U shaped at the handle so it will not come out there. At the bottom, it seems to be just a right angle into the locking mechanism. There is no clip but it simply will not come out. My best guess is that the E-clip on the lock barrel needs to be removed which would release the rod at the top. I have a clip tool on order so I have moved on for now.
    The rear door handles are simple enough and I have one off and expect to get the other and the passenger handles off today.
  4. #4 Re: Door handle removal
    Canada
    I finally cracked it. You have to wiggle the front of the handle out, which often requires lifting the handle, then rotate the handle anti-clockwise to get it off the rod. It is a sensitive job since a wrong move will certainly scratch the paint. When I install it, I will be masking off the area to prevent damage.
    - YouTube
  5. #5 Re: Door handle removal
    St. Louis
    Good find! I'm sure I can put this to good use at some point.
  6. #6 Re: Door handle removal
    Canada
    Yeah, it took me many attempts to make that video with one hand
    What a crazy pain to get these things out.
  1. 1993 4 Door Grand Prix Inside Door Handle
    By buickapollo in forum General Tech Discussion
    Last Post: 01-17-2013, 11:45 AM
  2. door handle bracket?
    By crunk04gtp in forum General Tech Discussion
    Last Post: 11-06-2012, 03:57 PM
  3. Door Handle
    By christinek in forum General Tech Discussion
    Last Post: 10-30-2009, 06:46 AM
  4. Door handle
    By prostock in forum General Tech Discussion
    Last Post: 09-04-2009, 01:02 AM
  5. Need help with the outside handle on the door =(
    By thenervemann in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-02-2008, 07:52 PM
