Thread: Pulsating steering - not the discs.
Results 1 to 4 of 4
  1. #1 Pulsating steering - not the discs.
    MD
    '99 Grand Prix GT
    When I'm driving and not braking, and I apply slight pressure on the steering wheel to turn on a curved road, I feel a very slight and subtle pulsation in the steering wheel. There is no pulsation when I brake, or when turning the wheel when the car is stopped (e.g. turning at a stop sign.)
    What's the cause of this? Is it something to do with the power steering pump?
    TIA
  2. #2 Re: Pulsating steering - not the discs.
    St. Louis
    Probably a worn hub bearing or an axle.
  3. #3 Re: Pulsating steering - not the discs.
    MD
    Quote Originally Posted by FordMan77 View Post
    Would I be able to tell by jacking up the front and checking play in the wheels? Would there be any way from the pulsation to tell which side may be affected?
  4. #4 Re: Pulsating steering - not the discs.
    St. Louis
    Yes, jack up the front end until both wheels are clear of the ground and push/pull on the tire at the 12 and 6 o'clock position (basically try to rock it inward and outward). Side to side won't tell you anything.
    If you get play in a hub it will show.
    Axles I usually just grab the cv shaft inbetween the booted areas and push up on it. If there is excessive play then that cv is likely getting worn. There might be a better way to check an axle on here somewhere, it's just what I personally do.
  1. Brake Discs
    By lewis1952 in forum General Tech Discussion
    Last Post: 02-15-2014, 04:52 PM
  2. Hot brake discs
    By whitehead in forum Brakes/Suspension/Chassis
    Last Post: 05-31-2011, 02:07 AM
  3. Pulsating idle
    By slappy in forum 3.4L V6 (LQ1) DOHC
    Last Post: 05-30-2010, 09:11 PM
