Thread: PCV valve operations
Results 1 to 2 of 2
  1. #1 PCV valve operations
    Sep 2013
    Edmonton Alberta
    I have a 2007 Grand Prix with a 3800 V6. I took it in to have it be checked because of none starting in cold weather. One problem they found was with the PCV tube which is on top of the intake tube after the mass air flow sensor and goes to the intake manifold. But the PCV valve is on the other side of the engine under the MAP sensor. How does this version of a PCV valve work. I have not looked at one in over a decade. They used to go from the intake to the top of the valve cover with the valve in between. Where does this version connect with the crankcase and what is this tube suppose to do?
  2. #2 Re: PCV valve operations
    St. Louis
    IIRC the PCV system is routed internally via the lower intake manifold.
  1. Tie-Rods. Correct Order of Operations
    By CHI2000GTP in forum General Tech Discussion
    Last Post: 08-30-2017, 12:12 AM
  2. aluminium valve covers, 90 lb ls6 valve springs for sale
    By SgtMarshal in forum For Sale - Parts
    Last Post: 09-04-2014, 04:30 PM
  3. Stock intake valve versus 1.9 intake valve...worth it?!
    By slimguns in forum General Tech Discussion
    Last Post: 03-30-2013, 05:18 PM
  4. Replies: 26
    Last Post: 08-30-2012, 04:50 PM
  5. headers, pully drop, pcm order of operations???
    By drewzilla03 in forum General Tech Discussion
    Last Post: 07-18-2011, 09:19 AM
