Thread: Code P1133
Results 1 to 3 of 3
  1. #1 Code P1133
    Jun 2018
    Schweiz
    Hi all
    And now I checked all....
    The sensor is a Denso its connected.
    Don't know what to check next. This code is awesome and I want to find the failure.
    But what the next steps.
    If youave some tips or tricks please post
    ​thanks
  2. #2 Re: Code P1133
    Jun 2018
    Schweiz
    Found one failure...it has a leak in the exhaust.
    ​Will fix that and then take a look
  3. #3 Re: Code P1133
    Jun 2018
    Schweiz
    ​And now the solution for all this.
    On the transmission you have the normal connectors and two wires going to the ground of the transmission.
    The garage who did the remodeling to HD forget to connect these two wires.
    I connected them and got no codes or check engine light anymore.
    ​Seems it is solved.
  1. p1133 ?? what is this code
    By 1bad3800 in forum General Tech Discussion
    Last Post: 12-14-2016, 12:12 PM
  2. Stumped with p1133 and p0137
    By chris99gtp in forum General Tech Discussion
    Last Post: 06-25-2015, 06:37 PM
  3. engine code P1133
    By SgtMarshal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2014, 08:54 AM
  4. Header o2 Sensor Code P1133 Help
    By brandonl2000 in forum General Tech Discussion
    Last Post: 02-17-2012, 12:27 PM
  5. p1133 code
    By Spartanzz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-03-2011, 10:57 PM
