Thread: It goes on and on with my car
Results 1 to 12 of 12
  1. #1 It goes on and on with my car
    Jun 2018
    Schweiz
    Hi all
    I posted about the mess with the codes on my 2000 Pontiac Grand Prix GTP before here in the forum.
    Last code was P1133
    But now I have:
    P1133
    P1361
    P1362
    And now I have a check engine light.
    It goes on and on theres no end or anything I think all on this car is a mess.
    These codes are for the ignition module and the crankshaft position sensor I think.
    ​What can I do against this?
  2. #2 Re: It goes on and on with my car
    St. Louis
  3. #3 Re: It goes on and on with my car
    Jun 2018
    Schweiz
    Yes and no it was there after the check engine light came on.
  4. #4 Re: It goes on and on with my car
    St. Louis
    FYI, my post is a link to some info if you didn't click on it.
  5. #5 Re: It goes on and on with my car
    Jun 2018
    Schweiz
    Yes saw it...thanks
    Thats why the indicator light is off now:
    • The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
  6. #6 Re: It goes on and on with my car
    Jun 2018
    Schweiz
    And now next thing:
    Sometimes car has misfires with ignition and after this the Computer goes wild.
    All is blinking
    I think this is due the codes I have the p1361 and p1362 codes
    ​I don't know but the car is only scrap and I can't drive it anymore
    Indicator light is on again
    If I have a short in the wires somewhere then good night can't find out by myself.
    So many parts are new: The O2 sensor by the engine, the igition modules the ICM don't know what to do now
  7. #7 Re: It goes on and on with my car
    The Boss Iceman6669's Avatar
    Jun 2011
    I would check the harness for the cam and crank position sensors. If the harness gets messed up it can cause those codes to pop up.
    2011 F-150 Yote powered
  8. #8 Re: It goes on and on with my car
    Jun 2018
    Schweiz
    Where is the harness for the cam?
    For the crankshaft sensor its ok
  9. #9 Re: It goes on and on with my car
    St. Louis
    It comes off of the harness for the ICM if I recall. It runs down under the coils/ICM and into the front of the engine. Cam is up top and then the crank sensor lives behind the crank pulley/balancer. It can get rubbed by the drive belt if not secured properly, seen that one before.
  10. #10 Re: It goes on and on with my car
    Jun 2018
    Schweiz
    Ok thanks tomorrow I will take a look
  11. #11 Re: It goes on and on with my car
    Jun 2018
    Schweiz
    And now the solution for all this.
    On the transmission you have the normal connectors and two wires going to the ground of the transmission.
    The garage who did the remodeling to HD forget to connect these two wires.
    I connected them and got no codes or check engine light anymore.
    ​Seems it is solved.
  12. #12 Re: It goes on and on with my car
    Aug 2021
    Texas
    good for you !! great news !!
