Thread: Washer motor does not work -replaced switch and pump
Results 1 to 4 of 4
  1. #1 Washer motor does not work -replaced switch and pump
    May 2008
    Florida
    Washer will not spray. Replaced pump and just replaced the multi function switch but still no-go.
    Anything obvious I might be missing?
    My low speed wipers never worked so fixed one thing with the stalk, at least.
  2. #2 Re: Washer motor does not work -replaced switch and pump
    St. Louis
    Check the fuses?
  3. #3 Re: Washer motor does not work -replaced switch and pump
    May 2008
    Florida
    Quote Originally Posted by FordMan77 View Post
    Check the fuses?
    It is supposed to be tied to the same one as the wipers, which work fine.
  4. #4 Re: Washer motor does not work -replaced switch and pump
    St. Louis
    Time to test for voltage at the plug to the pump.
  1. Replies: 7
    Last Post: 01-31-2015, 07:12 PM
  2. Replies: 2
    Last Post: 01-15-2014, 11:43 AM
  3. Replies: 0
    Last Post: 05-05-2013, 05:05 PM
  4. washer fluid pump / blower motor resister
    By swags2000gt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-29-2012, 09:31 PM
  5. washer pump????
    By GTPJOE90 in forum General Tech Discussion
    Last Post: 06-12-2010, 11:24 PM
