Thread: Leak
Results 1 to 7 of 7
  1. #1 Leak
    Sep 2017
    Texas
    So i have a leak some where in the passenger backseat area, my floor is soaked.
    The front passenger is completely dry, was thinking it was coming from there at first because that's been a problem with most people's. I can't seem to locate where the water is coming from.
    The window and door seals are dry as well.
  2. #2 Re: Leak
    you parked ass lower then the front? the cowl can leak then run in the channel to the back floor. you'll have to pull some carpet up to see the water tail.
  3. #3 Re: Leak
    Sep 2017
    Texas
    It is parked on a hill and good to know also, I'll have to get the fix for it. I have a 1 piece so I was hoping not to do it.
  4. #4 Re: Leak
    its not all that bad to get the whole cowl off, the replacement part is like 10 bucks.
  5. #5 Re: Leak
    Sep 2017
    Texas
    That's definitely great to hear, do I need a puller for the windshield wipers?
  6. #6 Re: Leak
    i used a small 2 jaw puller on mine i tried to pry em off but no dice, didnt want to slip and bust the windshield. put the puller on, get it tight and then tap the drive bolt with a hammer should pop off if it dont the next turn on the puller should be easy to turn, so snug it back up tap it again. tap i mean good firm tap hard but not to hard.
  7. #7 Re: Leak
    Sep 2017
    Texas
    Alright I'll take a look at habor freight for a small puller like that, hopefully they have one for cheap
  1. Small coolant leak turned into a large coolant leak
    By DreamerGT in forum General Tech Discussion
    Last Post: 09-23-2016, 11:00 AM
  2. Oil Leak After *Attempting* to Replace Coolant Leak
    By CDAllenInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2013, 12:54 AM
  3. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  4. vac leak, O2 code, exhaust leak.
    By al2000gtp in forum General Tech Discussion
    Last Post: 07-02-2012, 03:46 PM
  5. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
