Thread: Brake job
Results 1 to 5 of 5
  1. #1 Brake job
    Mar 2016
    Usa
    I am trying to save some money by doing my brakes myself which I have done before, no biggie. My main area of concern is with bleeding. I have heard both sides of the story where some say you MUST bleed them while other people say as long as no air enters the line (keeping the cap on the master cylinder) you may not have to. What have you guys experienced doing it yourselves? I have a 2008 grand prix.
  2. #2 Re: Brake job
    Jun 2018
    Lehigh Valley
    If the fluid is really dark bleed all 4 brakes. If not, don't bleed. I loosen the master cylinder cap when compressing the calipers. Never had a problem.
    '97 Grand Prix GT Coupe
    '05 Grand Prix GTP Sport Red Metalic SOLD
    '05 Grand Prix GTP Silver
  3. #3 Re: Brake job
    Jul 2010
    Coquitlam,BC,Canada
    Changing pads and or rotors, no need to bleed.
    Changing calipers, hoses and or master cylinder, must bleed.
    And, as GYSOT1 said, if the fluid is dirty, should bleed.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  4. #4 Re: Brake job
    like stated, compress the caliper pistons, install new pads, pump brakes to get the pedal back. all is good to go.
    there is a good chance the fluid is super old. it dont take much to flush it. i use a diy one man bleeder. aka a bottle with a hose into it from the bleeder nipple. pump pedal and it flush out the old and any air. dont let the master run dry. keep a eye on it and keep it from running dry.
    if you got a old turkey baster i use that to suck out 95% of the old fluid, re fill with new fluid, then flush.
  5. #5 Re: Brake job
    My procedure:
    Jack and support front or rear (whichever you are doing)
    Lift hood and loosen master cylinder cap so there's no back pressure when compressing piston.
    Remove caliper and a brake pad.
    Compress piston using the brake pad so you don't hurt the caliper piston
    Remove bracket
    Remove clips from bracket one at a time and clean the bracket in that area with a wire brush
    Ensure your new clip matches the old one and install new clip (do for all clips)
    At this point you can lightly lube the clips with a little caliper grease and if you'd like you can put the new pads in as well or wait until you install the bracket again.
    Remove rotor
    Clean new rotor with brake cleaner to remove oil, install new rotor
    Install caliper bracket (and pads if you didn't already)
    Install caliper
    Ensure all bolts are torqued or good and tight.
    Put wheel back on
    Next side
    When brakes are complete, tighten master cylinder cap and close hood
    Lower vehicle most of the way down and torque lug nuts
    Start car and pump brake pedal until it's firm again.
    That's it.. quick and simple. Over time the fluid does absorb moisture and other contaminates which a full flush will help and make your brakes feel much better.
  1. Brake Job DIY
    By Zinister09 in forum General Grand Prix Discussion
    Last Post: 02-20-2015, 07:05 PM
  2. Brake likes to put out . . . noise and brake dust
    By barbschwartzer in forum Brakes/Suspension/Chassis
    Last Post: 02-01-2015, 12:46 AM
  3. Replies: 2
    Last Post: 07-20-2013, 08:25 AM
  4. brake parts to get for brake upgrade??
    By colindunn in forum Brakes/Suspension/Chassis
    Last Post: 01-03-2011, 08:59 PM
