Thread: Rear 1/4 panel patch for an 04 Grand Prix?
Results 1 to 8 of 8
  1. #1 Rear 1/4 panel patch for an 04 Grand Prix?
    SE Level Member BANDIT's Avatar
    Ontario, Canada
    Hey guys, just wondering if anyone has found a source for the rear drivers side 1/4 panel? I'd like just a repair patch for the area from the fuel opening to the wheel well or the entire 1/4 panel just to get a patch I can cut out. Or is this one of those jobs where I'll have to get just a flat piece of sheet metal and fabricate it to fit? I've searched the forum to see if it was posted but came up with nothing and the area I'm asking about seems like a common area for rust.
    04 GP GT Bone stock, just like me! 09 G8 GT...oh yeh!!!
  2. #2 Re: Rear 1/4 panel patch for an 04 Grand Prix?
    They don't make one as far as I know.
    You'd have to custom make it yourself or go to the junkyard and cut the section of metal out you want from a car there, if you can find one.
  3. #3 Re: Rear 1/4 panel patch for an 04 Grand Prix?
    Ontario, Canada
    Thanks Five, I googled 04 Grand Prix 1/4 panels to death but no one makes them. Hoping someone here had a source, oh well I guess I can try the wreckers or have to get the hammer and dollies out and just start pounding. Tack, bang-bang, tack, tack, bang-bang, tack, tack, mother f****r!
  4. #4 Re: Rear 1/4 panel patch for an 04 Grand Prix?
    Jan 2014
    AR
    Aftermarket quarter panels are only made for classics. GM has quarter panels for over $300, and salvage yards are wanting over 400. So I would definitely say make it if theres not a solid one in your local junkyard. For fabrication, make the panel with posterboard first then transfer to metal. Its much easier that way.
  5. #5 Re: Rear 1/4 panel patch for an 04 Grand Prix?
    GT Level Member mguzzo's Avatar
    Buffalo NY
    the panel in that area is a double layer - there's the inner wheel well and outer skin. The reason is rusts is because moisture gets trapped up between the layers, and there is a foamy goop insulator around the gas door area. You'd have to work on the panel from the outside and inside the trunk as well.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  6. #6 Re: Rear 1/4 panel patch for an 04 Grand Prix?
    Ontario, Canada
    Thanks for the tips guys, guess it'll be a home made cut and patch (poster board template) and topped with a yet to be determined application of Bondo.
    As far as working from inside the trunk, will removing the inside cardboard panel give me access to the inside of the outer skin?
  7. #7 Re: Rear 1/4 panel patch for an 04 Grand Prix?
    Antioch, IL
    When I put a temp plate in that area 7 years ago there is no way in hell you can access that from the trunk. Its a big void between the outside metal and trunk. Finish on the outside and then maybe perhaps look up underneath the bumper cover area to seal off the inside?
    2009 Challenger SRT8
    Expert at being gay.
  8. #8 Re: Rear 1/4 panel patch for an 04 Grand Prix?
    Ontario, Canada
    Once I get a section cut out I'll scope the rest of the skin to see how bad it is inside. I've heard Crown sells a can of their rust spray and depending on how bad the rot is in the rest of the fender I may just give it a spray then weld the piece in place. Then for the actual piece once it's cooled drill a small access hole from the trunk so I can coat the new patch. It doesn't have to be perfect seeing as it's my winter beater since I got the G8, but I want it to be a winter car for as long as possible. Have to get an exhaust from the cat back as this one is almost falling off, just a stock set up as I don't want to invest a bunch of money and since I'm now retired the labour, knuckle skin, blood and burns are free . I may document my progress depending on how well it goes.
    Rear 1/4 panel patch for an 04 Grand Prix? Attached Images
  1. 2008 Grand Prix upper dash panel
    By daviddawg in forum Introductions/Noob Questions
    Last Post: 02-09-2017, 09:26 PM
  2. 97 Grand Prix door panel
    By DatRedGTP in forum Wanted To Buy - Parts
    Last Post: 01-18-2016, 12:23 AM
  3. '06 Grand Prix Valance Panel/Skid Plate Fell Off
    By JohnnyTwoTimesTwoTimes in forum General Tech Discussion
    Last Post: 06-19-2014, 10:24 AM
  4. 1994 Grand Prix GTP door panel
    By lakers16fan in forum Shops and Community Heroes
    Last Post: 06-04-2013, 02:17 AM
