Thread: Swapping gt to gtp (Google no help)
Results 1 to 5 of 5
  1. #1 Swapping gt to gtp (Google no help)
    GTP Level Member Rlugo87's Avatar
    Jun 2016
    Minnesota
    Sorry I bet this subject is beat but I picked up a nice (very nice) 02 gt, I was searching for a clean body to swap everything from my 01 gtp coupe into and I found one at a local car lot with a bum trans. But it's a gt not a gtp, I'm planning on swapping motor and transmission so I won't need to worry about the gear ratio, obviously I have a working gtp donor car so what all needs to come over? Pcm for sure, what on the harness needs to be changed? Fuel pump? Thanks for any info guys.
    Sent from my Moto E (4) using Tapatalk
  2. #2 Re: Swapping gt to gtp (Google no help)
    pcm and lop the map sensor pig tail off. put it in place on the gt.
  3. #3 Re: Swapping gt to gtp (Google no help)
    May 2008
    Schuyler, NE
    The fuel pumps are different. I would swap it over as easy as it is on these cars.
    I would swap the entire harness. There are little differences such as the map, injectors.
  4. #4 Re: Swapping gt to gtp (Google no help)
    GT Level Member Gregorius's Avatar
    Davenport, IA
    Isn't the passenger axle shaft shorter on the GTP?
    Dashboard Boost gauge/DIC?
    GTP badges from the donor
    Dude! Full Service Manuals! 2004-'08 User manuals, full docs wiring diagrams trouble codes... go look.
    WarStryker13's Google drive
    ... our lady of blessed exceleration, don't fail me now ...
  5. #5 Re: Swapping gt to gtp (Google no help)
    Jun 2016
    Minnesota
    Thanks for the info guys, the swap over has started as of today, I got a buddy who owns a pretty big shop and he offered to do the whole swap cheap if I let him have the 80k l36 that's currently in the new car. He is going to swap the entire drivetrain, motor, trans, axles.... We are also swapping over the fuel pump & radiator. I ordered ev6 to ev1 adapters for a fuel injector plug soultion and he is going to slice in the map sensor plug. While he is doing the swap I will be in the shop on my days off swapping the interior (my silver car had 2tone leather) and yanking out the fuel pump hot wire and moving it over. I will be pulling roof rails and special edition spoiler off the silver car too so if anyone is interested in those parts they will be available.
  1. Redirects from google.....
    By speedy2 in forum Forum Bugs/Suggestions
    Last Post: 10-10-2013, 08:47 AM
  2. The Things Google Does...
    By TLSheff in forum Off Topic Discussion
    Last Post: 05-16-2013, 01:41 PM
  3. Thanks Google
    By dpzelenak in forum Off Topic Discussion
    Last Post: 09-20-2011, 05:22 PM
  4. google plus!
    By OmegaRed in forum Off Topic Discussion
    Last Post: 07-13-2011, 03:47 PM
  5. Is yer Google broken?
    By BillBoost37 in forum The Rant Forum
    Last Post: 09-10-2010, 07:50 PM
