There is no other way to access the outlet that resides on the pass. side of the console without at least removing the console top. You didn't mention what year GP you have so I can only speak for the 97-03's. Open the cupholder, then gently pry up along the edge of the console top. It just clips in. Be easy on it and pull straight up and little by little the clips will let go. May have to move the shift lever to D to get it completely out. Then you will have access to the outlet. Never tried changing one this way but it will open up the area where it is mounted and where the wire harness is connected to it.
