Thread: Intermediate Steering Shaft
Results 1 to 7 of 7
  1. #1 Intermediate Steering Shaft
    Nov 2019
    WI
    Hi all. Got the infamous ISS clunk on my 2008 GXP. Just wondered what the difficulty level or time it took to replace it. Thanks.
  2. #2 Re: Intermediate Steering Shaft
    Oct 2014
    portland oregon
    There's a very recent thread about this issue.. seemed to be some what okish on the doablility side from reading.. biggest issue was to make sure the steering wheel doesn't spin in the process. Something about spring(s) in the steering wheel
    Sent from my SM-N920V using Tapatalk
  3. #3 Re: Intermediate Steering Shaft
    St. Louis
    Yea, don't spin the wheel while it's free or it will break the clock spring and fubar the airbag and other things.
  4. #4 Re: Intermediate Steering Shaft
    Nov 2019
    WI
    Thanks for the reply.
  5. #5 Re: Intermediate Steering Shaft
    lock the wheel dead straight, with the car on jack stands d/s wheel off. pop the boot off the rack remove the 11 mm bolt, under the dash at the base of the column is another 11 mm bolt remove that, now you need to lower the rear of the sub frame, put a floor jack under the middle rear jack it up to hold it up, then back out the two rear frame mount bolts 18 mm. they are long bolts, so back em out a couple inches, then lower the jack so the frame comes down to the bolts, but let the jack carry the weight. pop both ends of the shaft off pull it out.
    put the new shaft in the boot bolt it on the column, then pull it down to the rack's nub, and jack up the frame to the shaft end and wiggle it on, its a tight fit. will only fit on one way too. get the bolt back in the shaft then jack the frame all the way back up and tighten the frame bolts up. get the boot back on too.
    if the shaft will not go on, have a helper unlock the steering wheel and turn it ever so slightly each way till it lines up and goes on. generally if nothing moved it should just go back on, but sh it happens, old one might have slop new one is tight and it will be off a bit.
  6. #6 Re: Intermediate Steering Shaft
    Nov 2019
    WI
    Thanks for the tip about dropping the cradle. I would have struggled getting it out not knowing that.
  7. #7 Re: Intermediate Steering Shaft
    cradle drop is key. other wise it just a fight. once the boot is lifted off the rack the shaft bolt is looking back at ya. need a bout a foot of extensions to get it out easy like. then pry it up and off with a screw driver.
  1. Loose steering after replacing intermediate steering shaft on 06 GP GT
    By Tross901 in forum Other 3800 Powered Cars
    Last Post: 06-03-2015, 10:56 AM
  2. intermediate steering shaft
    By mstowe in forum Shops and Community Heroes
    Last Post: 10-08-2013, 07:02 PM
  3. [?] steering column plastic / intermediate steering shaft question
    By localhost127 in forum General Tech Discussion
    Last Post: 06-10-2013, 08:33 PM
  4. Steering Intermediate Shaft
    By stlmo_gtp in forum Brakes/Suspension/Chassis
    Last Post: 07-06-2009, 12:22 AM
  5. Intermediate Steering Shaft.
    By bentendo92 in forum General Tech Discussion
    Last Post: 09-18-2008, 07:04 PM
