Thread: 2006 Grand Prix Electrical issues
Results 1 to 6 of 6
  1. #1 2006 Grand Prix Electrical issues
    Mar 2017
    Laramie, WY
    Hi, I recently installed an aftermarket radio to my 2006 Grand Prix GXP. I used a couple of adapters, one being the ASWC-1 adapter and I've been noticing that probably about every third time I turn my car on, quite a few of my warning lights chime. It isn't just that the lights turn on, the functions like traction control and power steering are actually disabled. I have been asking around and I've been told that it's bad wiring. Does anyone know any details on this?
    Thanks.
    Sent from my SM-G935V using Tapatalk
  2. #2 Re: 2006 Grand Prix Electrical issues
    SWPA
    The warnings probably have nothing to do with the radio. You eithervhaveca bad hub or wiring going to the hub. When thst happens it affects Magnasteer too.
  3. #3 Re: 2006 Grand Prix Electrical issues
    Mar 2017
    Laramie, WY
    Ya I know it's probably nothing to do with the radio itself, but I think it does have to do with the wiring to the radio. Do you what issue in the wiring would cause that? It's quite a few warning lights that are triggered (~5 or 6).
  4. #4 Re: 2006 Grand Prix Electrical issues
    SWPA
    It's not the wiring to the radio. The ABS will cause all those lights.
  5. #5 Re: 2006 Grand Prix Electrical issues
    Oct 2011
    Toledo, OH
    Well, it's a GXP so there could be one wire in the radio harness that can cause that. There is a Vehicle Speed Sensor (VSS) wire for the nav system. If it got pinched or shorted out that may be an issue.
    That being said, Stealthee is correct that it's something to do with wheel hub sensor. Intermittent problem would suggest maybe a bad ground or dirty connector at the hub.
    7"
  6. #6 Re: 2006 Grand Prix Electrical issues
    Mar 2017
    Laramie, WY
    Okay thank you guys for your help. I will look into it.
  1. 1989 Grand Prix electrical issues
    By dennador in forum General Tech Discussion
    Last Post: 11-22-2015, 06:04 PM
  2. 2006 Grand Prix GT ABS&Electrical issues
    By Dtrick22 in forum General Tech Discussion
    Last Post: 02-22-2015, 02:23 PM
  3. 2004 Grand Prix Gt electrical issues
    By hydrashock in forum General Tech Discussion
    Last Post: 03-18-2013, 02:06 PM
  4. Help - Electrical Ac/ Heat issues 2002 Grand Prix GT
    By Brian1975 in forum General Tech Discussion
    Last Post: 07-15-2012, 04:01 PM
  5. 2000 Grand Prix Electrical issues
    By Stappen720 in forum General Tech Discussion
    Last Post: 09-24-2009, 06:32 AM
