Thread: Revving high at 55 60 mph
Results 1 to 8 of 8
  1. #1 Revving high at 55 60 mph
    Oct 2017
    Nunya way 124
    I have a 2002 gp gt 4 door, when at 60mph I'm revving about 2k and on hwy about 2500, anyone know what it might be?
  2. #2 Re: Revving high at 55 60 mph
    you lost over dive, aka the 4 th gear hub.
    if you get in the hwy and pull it into 3 rd and the rpms stay the same, you just confirmed it.
  3. #3 Re: Revving high at 55 60 mph
    Word.
    4th gear with 2.93 is about 1900-2000 and with 3.29's it's like 2300ish doing about 68-70mph.
  4. #4 Re: Revving high at 55 60 mph
    Oct 2017
    Nunya way 124
    I shift into 4th tho so can it b that?
  5. #5 Re: Revving high at 55 60 mph
    If it shifts into every gear and does change rpm when you pull it back down into 3rd, something else is way wrong.
    Like internal transmission failure, major slipping or something.
    The most likely cause was said, if the 4th gear hub is gone. RPM at 60mph in 4th gear should not be 2500rpm, should be 500-600 less than that.
  6. #6 Re: Revving high at 55 60 mph
    Oct 2017
    Nunya way 124
    Is 2k at 60 2500 at 70 I feel 2k is high for 60 as ive been getting horrible mpg
  7. #7 Re: Revving high at 55 60 mph
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    I third that. It's your 4th gear. Sucks to get to, but if you want to be cheap, you can access it through the wheel well with subframe dropped. I really do not recommend this due to 1) contamination and 2) if you're doing that much work, might as well rebuild your transmission while you're there. It's really not that bad. Just did mine.
  8. #8 Re: Revving high at 55 60 mph
    Mar 2017
    Internet
    It's the 4th hub. Search on my name and 4th hub shaft or something like that. It's not a horrible fix.
  1. Revving itself when driving
    By aldgrandprix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-12-2012, 01:15 PM
  2. Slight hesitation while revving
    By dsmuts in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-17-2012, 01:48 PM
  3. Car stalling and revving up
    By gpse2000 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-24-2011, 03:48 AM
  4. Revving when RPM's below 2000
    By Badley in forum General Tech Discussion
    Last Post: 03-31-2011, 08:44 AM
  5. Rapping/Rattle at Idle, goes away when revving
    By hoont79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-07-2010, 05:25 AM
