Thread: Revving itself when driving
Results 1 to 6 of 6
  1. #1 Revving itself when driving
    Aug 2012
    Auburn Hills
    Hello there, I am new to the fourms. I have a question about my 2000 GT. When driving I've noticed that it will rev itself every 30 seconds or so. It will only rev maybe 300 rpms or so and it seems to happen no matter what rpm, it just spikes up. I put it in cruise the other day and it would still do it as I was cruising along. However the funny thing is that when I come to a complete stop the problem seems to go away. Any help would be great, thanks.
  2. #2 Re: Revving itself when driving
    Are you throwing any codes?
  3. #3 Re: Revving itself when driving
    HUDSON
    TCC unlocking?
  4. #4 Re: Revving itself when driving
    Pennsylvania
    Unplug the MAF and drive around like that, see if the problem goes away. I had almost the same symptom and my MAF kicked the bucket.
    Sport Edition Kv5 18x8
  5. #5 Re: Revving itself when driving
    Aug 2012
    Auburn Hills
    I was getting the code for the first O2 sensor so I replaced it. I am thinking now it could be the torque converter because at times when I am coasting then press the gas it takes a few seconds for the transmission to engage. I can hear and feel when it does engage.
  6. #6 Re: Revving itself when driving
    Pennsylvania
    Quote Originally Posted by aldgrandprix View Post
    Before you put any money into it, just try my suggestion. You're describing part of the problem I had before it got worse. Just unplug the sensor and drive around for a day, see if it improves, if it doesnt improve then atleast you ruled that out.
  1. Slight hesitation while revving
    By dsmuts in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-17-2012, 01:48 PM
  2. Car stalling and revving up
    By gpse2000 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-24-2011, 03:48 AM
  3. Engine revving but barely moving
    By MBigelow in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-10-2011, 04:02 PM
  4. Revving when RPM's below 2000
    By Badley in forum General Tech Discussion
    Last Post: 03-31-2011, 08:44 AM
  5. Engine Revving after filter change
    By mikeh in forum General Tech Discussion
    Last Post: 01-18-2010, 12:29 AM
