This issue has persisted since I've owned the car and it's intermittent. The car will sometimes start and run just fine the first time. Other times it will start, rpms will hop up and down a split second and smooth out, and sometimes it will just flat out start, then stall, then start up and run.
My crank sensor died so YAY I thought it was that - nope. MAF is brand new. FPR is new. Plugs, wires, fuel filter - all new. Cleaned IAC and TB.
So what could it be? Ignition coil? fuel pump check valve? fuel injectors? Car runs and shifts just fine though. Lots of power.
