Thread: Low beams won't turn on
Results 1 to 10 of 10
  1. #1 Low beams won't turn on
    Sep 2015
    Cheyenne, WY
    Wanted to go get a milkshake but I got no headlights!
    (I ain't got a blender to make my own milkshakes either!)
    Doesn't matter if the switch is in AUTO or ON.
    High Beams do work.
    If set to ON and I shut the car off the HL warning chime comes on.
    Bulbs are good.
    Fuses #3 & #4 are good.
    No blender, no headlights, no milkshake.
    Give me some ideas!
    About the headlights that is!
    2007 Antique Bronze Metalic Grand Prix GT...bone stock.
  2. #2 Re: Low beams won't turn on
    Likely the HDM Module in the fuse box.
    It's a special 5 pin relay for the headlights, seen them go bad often.
  3. #3 Re: Low beams won't turn on
    Sep 2015
    Cheyenne, WY
    Underhood fuse box or passenger side dash panel?
  4. #4 Re: Low beams won't turn on
    Sep 2015
    Cheyenne, WY
    Nevermind...I found it.
    #35 underhood.
    I'll replace it in the morning.
    Thanks FFDP!
  5. #5 Re: Low beams won't turn on
    That is where I would start, replaced several thoughout the years for no low beam headlights but everything else working.
    Of course none of the other relays in the fuse box have the same 5 pin connector style so you can never swap them around to test.
  6. #6 Re: Low beams won't turn on
    SWPA
    There is a recall on the HDM
  7. #7 Re: Low beams won't turn on
    Sep 2015
    Cheyenne, WY
    A HDM solved the problem...$38.00 for the little bugger!
    Thank you guys!
  8. #8 Re: Low beams won't turn on
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by LEVELX View Post
    Expensive milkshake. LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  9. #9 Re: Low beams won't turn on
    GTP Level Member
    Aug 2012
    st louis park, MN
    I've had this go out 2 or 3 times on my 08. There is a recall but it's not even worth my time to try to go to the dealer.
    Napa will replace theirs for a couple 3 years if I remember correctly - just hold on to your receipt!
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  10. #10 Re: Low beams won't turn on
    Sep 2015
    Cheyenne, WY
    And I still haven't gotten my milkshake!!!
    I'm going to get two tonight!
  1. 05 gtp lows beams stay on with high beams.
    By pontiacGTP123 in forum General Tech Discussion
    Last Post: 06-15-2014, 01:24 PM
  2. Replies: 4
    Last Post: 03-22-2014, 04:04 PM
  3. Hi beams and low beams at the same time?
    By PurpleGuy in forum Audio, Security & Visual Electronics
    Last Post: 06-06-2012, 12:38 AM
  4. Help guys! low beams wont turn on??
    By 01GTPSPECIAL in forum General Tech Discussion
    Last Post: 05-07-2012, 01:40 PM
  5. High beams turn on intermittently when using turn signals
    By Boomersooner in forum General Tech Discussion
    Last Post: 01-13-2012, 08:31 PM
