Hi guys,
So I have some odd crap happen to my cars, or maybe it's normal and I just don't know, maybe you guys can shed some light on this stuff. So since installing my intense tune in my 98 riviera I have been setting a p1811 code and having some pretty hard shifts ( car shifted flawlessly before pcm) btw here's a little list of what's done to the car ( 4inch custom fwi, 160 tstat, al 104's, 3.5 pulley) now before the tune and pulley I had 0* or at all times, after pcm and pulley I was seeing up to 9* kr when hitting 2nd gear but only occasionally never consistent and never the same sometimes I would see 1* on up to 9* being the worst. So today I dropped the pan on my car to change fluid and install a zzp shift kit in hopes of bandaiding the p1811 for the time being, here's what I found, cherry red fluid that smelled clean not burnt, clean pan and magnet, so hmmm why am I having a trans problem all of a sudden? I expected to find a ton of material in the pan. I installed the kit and filled her up with dex vi. After multiple trys deleting codes and going through shift cycles I was still getting the p1811 code and harsh shifts. So I figured why not toss the stock pcm back in since that's when this issue started. And wouldn't ya know, the code is gone and my shifts are back to normal, I even put about 70 miles on stop and go to be sure, now here's the kicker, my scans show 0* kr on the stock pcm at all times, yet I had some pretty bad kr with the intense tune, so the car shifts perfect, pulls harder and has no kr on a factory tune, is this common of canned mail order tunes? I sent John at intense an email about this to see if it's something we can fix or if I can just get a refund on the tune although I'm sure that won't happen as they have a no return policy on pcm's. If i can't get a refund for it I will post it here at core price if anyone has a use for it, it's the same pcm as 97-03 gtp and I'm sure it's the exact tune you would receive for said car. Thanks for any input guys. Overall I'm pretty happy I took care of my trans code and eliminated my kr spikes by going back to a stock part haha
Sent from my SM-S727VL using Tapatalk
