Thread: Removing broken manifold crossover pipe studs
Results 1 to 13 of 13
Threaded View
  1. #1 Removing broken manifold crossover pipe studs
    MD
    '99 - 3800 engine
    I need to remove the broken studs at the rear of the manifold crossover pipe (where it connects to the exhaust).
    See pic.
    I believe these are studs with double nuts and they do not thread into the lower flange. Can anyone confirm? I know the nuts are frozen tight, but can you also confirm that the lower nut is not welded to the lower (exhaust pipe) flange? If this is true, I should be able to just punch these babies through. Just want to be sure before I start banging away.
    Thanks
  1. Crossover pipe leaking?
    By juggernaut56 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-27-2015, 12:11 AM
  2. crossover pipe
    By backinblackgtp in forum General Tech Discussion
    Last Post: 04-12-2010, 08:57 PM
  3. ZZP Crossover Pipe
    By SilverGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-02-2009, 04:46 PM
