Thread: Camber adjustment??
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #21 Re: Camber adjustment??
    Quote Originally Posted by cheatah faheatah View Post
    Pic no good. 8-(
    pic was his sig. see that faint line above it. sig line.
  2. #22 Re: Camber adjustment??
    it maybe just me, but if i right click the non view able pic, and open in new tab, it opens in the persons pb account and you can see the pic. unless its private, then you see nothing.
  3. #23 Re: Camber adjustment??
    Nov 2012
    Madison
    Quote Originally Posted by Swiggles View Post
    I hated using the camber bolts, they are super tight.
    Super light??
  4. #24 Re: Camber adjustment??
    Put some glasses on, it's a "T".
    lol
  5. #25 Re: Camber adjustment??
    Nov 2012
    Madison
    lol
    Well what the hell does super tight mean. Is that camber bolt kegels.
    I thought he was refering to the camber bolt shaft size so maybe he did mean the camber bolt kegels.
  6. #26 Re: Camber adjustment??
    May 2016
    Burns City, Indiana
    As a 30yr alignment tech, let me say that the aftermarket adjuster bolts, if installed properly work fine for general alignments.
    I would simply, when car came in and bosses would not want to sell or even stock them for sale, I would raise car by frame or body and simple remove lower strut bolt, loosen upper and pull wheel out and use carbide grinder to open slot to match spindle. Snug lower bolt by hand. Set car down and loosen upper bolt and then while car is sitting on wheels and machine is reading I would then use hand tools to "work" lower bolt and watch live feed as camber drops. I would have impact with sockets/swivel on one of the bolts as it gets to preferred specs hit the gun to lock it down . I generally can get most cars to preferred specs easy enough. I just hate most people want cheap alignment NOT proper alignment. But then good techs are hard to find.
  1. Dic date adjustment
    By raygt2005 in forum General Grand Prix Discussion
    Last Post: 12-08-2012, 10:25 AM
  2. valve adjustment
    By chevyman39452 in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-23-2012, 02:56 PM
  3. Inferno hood adjustment??
    By tmackster in forum Visual/Body Modifications
    Last Post: 07-03-2010, 03:26 PM
  4. BBV adjustment = +2psi !
    Last Post: 07-14-2009, 03:51 PM
  5. Headlight Adjustment
    By 97GP in forum General Tech Discussion
    Last Post: 08-17-2008, 11:28 PM
