stock 98 Olds Intrigue. turn key to accel on and fuel pump primes. when turning to start nothing, no clicks from outside the car nor anything under the steering column. batteries at ~11-11.1v and doesn't drop when turning to ignition. swapped the ignition relay (under fuse box) with another one (fan relay) and no go. The only things left unchecked which im guessing on is a bad starter or a bad ignition switch relay that's under the steering column.
what's everyone's thoughts? im thinking about jacking the car up and tapping the starter around as well as checking the connectors on there. it ran fine a few days ago but my pop parked it for 4-5 days and we had a harsh storm come by 2 days ago.
