Re: Front sub-assembly bushing and sway bar
wont hurt unless you snap a bolt off, if you clean it up you can see where its seeping from exactly. car off the fluid is way over the pans gasket.
sometimes the pan bolt holes dimple, then the pans not pulled as tight. could try one of them metal plates some older tannys had to spread the bolts load out on the pan.
Will take a closer look and see if any are loose.
The dorman brand does not look correct given the rear subframe bushing I just removed.
It's a lot smaller and no flange
This is the part number provided by AutoZone
These are the GM parts number for the rear sub-frame bushings. I guess you can re-use retainer and bolt, which saves me about $30.00.
10249731 Insulator, Upper....$38.93
10248771 Insulator, Lower.....$18.75
11611679 Insulator, Retainer...$10.80
10410940 Insulator, Bolt.........$5.94
https://uploads.tapatalk-cdn.com/201...3619e2f0a4.jpg
New sway bar installed. Applied some teflon tape before installing bushing. Awaiting rear subframe bushings from GM
https://uploads.tapatalk-cdn.com/201...2fca6823a9.jpg
Is this insert really needed when replacing upper bushing? I peeled it off from frame of body.
WTH? The subframe looks brand new
HighOctaneRacing
I degreased it and wiped it down. I always try and keep it grease and oil free.
Well that's a good damn job lol
Thank you sir. The rest of the car looks much like it...lol
Regular upkeep is the only way to keep this car running optimally. Of course this means 💰
