Thread: Rounded oil drain plug
Results 1 to 17 of 17
  1. #1 Rounded oil drain plug
    Jul 2012
    Bloomington, IL
    So I decided to start changing the oil myself in my '05 GTP, and I get under the car to find an almost rounded out bolt. There was no way that thing was coming off with a 13mm socket or wrench. Anyone else run into this, and what are the options? It's not exactly an easy bolt to maneuver around with the tranny pan right there to try and use a "bolt out" socket. I may just have to cut my losses at this point and take it to the shop to see if they have the tools to do it.
    2005 GTP - Headers, 3" DP, resonator, and catback, CAI, 605 plugs *Sold*
    2016 WRX Premium - Stage 2 E30
  2. #2 Re: Rounded oil drain plug
    Vise grips, big ones.
  3. #3 Re: Rounded oil drain plug
    Jul 2012
    Bloomington, IL
    I just could not get the leverage needed for the vise grips with just the ramps that I have. I took it up to the chevy dealer, and they actually put it up on the lift, got the leverage they needed and got it loose. And then they just snugged it up for me. And all it cost me was $8 for a new plug that they had in stock. Whew!
  4. #4 Re: Rounded oil drain plug
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    By "bolt out" socket, do you mean a six sided a size smaller + hammer? Vice grips are last usually.
    Oh, the pan right there... Yeah, idk. I can't even get any socket in there.
  5. #5 Re: Rounded oil drain plug
    St. Louis
    No, the bolt-out sockets are designed with cutting edges in them so they can bite into a rounded off bolt/nut and allow it to be removed.
  6. #6 Re: Rounded oil drain plug
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    Small pipe wrench ??
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  7. #7 Re: Rounded oil drain plug
    Jul 2012
    Bloomington, IL
    Yes. Bolt out sockets are exactly what Fordman listed. I would've went that route if the dealership hadn't helped me. Up on the lift, they made short work of it with the vise grips. I was just glad to see that bolt loose.
  8. #8 Re: Rounded oil drain plug
    SWPA
    I've had to use a chisel to get oil drain plugs out before. It was my first oil change on the car, and the most recent oil change on it had been done at Valvoline according to the sticker on the windshield. They must have used a Snap-On impact gun turned to full torque and kept hammering long after it was too tight.
  9. #9 Re: Rounded oil drain plug
    get your hands on a small pipe wrench aka monkey wrench, that sucker will rip that bolt free easy.
  10. #10 Re: Rounded oil drain plug
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    I love my big vise-grips...
    I have a 12 inch pair that'll even fit on the spindle nut. Too bad they don't fit on the inner tie rods though....
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  11. #11 Re: Rounded oil drain plug
    pipe wrench crushes vise grips of any size, pipe wrenches are made to turn pipes, pipes are round last time i checked, cant say ive ever had a pipe wrench break free that was adjusted properly on the item to be loosened.
    vise grips help make bolts round to start with lol
  12. #12 Re: Rounded oil drain plug
    Oct 2014
    Frederick, MD
    They only make bolts round if you don't get them tight enough...
    12 inches is quite a bit of leverage. especially when you use channel locks to get the vise grips closed. Lol
  13. #13 Re: Rounded oil drain plug
    dollars to donuts a pipe wrench bites tighter and works better tho. dont need channel locks to clamp em shut either, spin the wheel.
  14. #14 Re: Rounded oil drain plug
    Oct 2014
    Frederick, MD
    Oh yeah, guaranteed... But I have vise grips and channel locks, don't have a pipe wrench. Lol
  15. #15 Re: Rounded oil drain plug
    they are most handy, everyone should have one laying around the house.
  16. #16 Re: Rounded oil drain plug
    Jul 2012
    Bloomington, IL
    I have one, but it's a 20 incher. I may have a little trouble getting that one under the car on stands. Lol.
  17. #17 Re: Rounded oil drain plug
    that will work. you hold it up level so to say with the pan and pull.
  1. Oil drain plug size
    By MrTube in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-16-2012, 12:54 PM
  2. Radiator drain plug
    By bishdog25 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2010, 10:40 PM
  3. drain plug oil leak
    By 05grandprixgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-19-2010, 02:34 PM
  4. help! - oil drain plug
    By mpiacent in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-14-2010, 05:27 PM
  5. Oil drain plug
    By SlowM90 in forum General Tech Discussion
    Last Post: 12-22-2009, 12:05 PM
