Thread: Front end creaking noise
Results 1 to 8 of 8
  1. #1 Front end creaking noise
    Jul 2012
    Bloomington, IL
    My son has a 2007 GP Base with about 210K miles. I was driving it today, and I noticed when you start to take of slowly you hear a creaking noise coming from the front end. And if you punch it from a dead stop, it's more like a big clunk. Whatever it is, it doesn't sound good at all. Could it be a wheel bearing, tie rod?? Hopefully nothing to do with the tranny.
    2005 GTP - Headers, 3" DP, resonator, and catback, CAI, 605 plugs *Sold*
    2016 WRX Premium - Stage 2 E30
  2. #2 Re: Front end creaking noise
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    Prolly just the springs unloading, rust on rust. When's the last time it got new struts ? Proper diagnosis would require jack & wiggle both front wheels, checking for play in ball joints, hub bearings, tie rod ends.... turn your head and cough...
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  3. #3 Re: Front end creaking noise
    Jul 2012
    Bloomington, IL
    We've had the car for 4 years and the struts haven't been changed. From the looks of it, they never have been. Is there a good way to check if it's the struts?
  4. #4 Re: Front end creaking noise
    May 2016
    Rouge Island
    Quote Originally Posted by lawadm1 View Post
    Leaking, excessive rebounding after pushing down on front of car a few times then letting go. Good struts will settle motion fast, worn ones will allow more pogo-ing. Other things could be motor mounts, sway bar and lower control arm bushings, ball joints......with those miles many things could be worn out...
  5. #5 Re: Front end creaking noise
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    Quote Originally Posted by cheatah faheatah View Post
    Kinda my thought on it, too. You could take it in or shake things to look for the major issue(s), or start replacing what you can one thing at a time.
    My front end will probably be pretty shot before I get to it. I think right now my LCA's need the most attention.
    Without more detail than a sound, it's kinda hard to tell what's totally worn out on your 07.
  6. #6 Re: Front end creaking noise
    Jul 2012
    Bloomington, IL
    Yeah. I'll try and get it on jack stands and take the wheels off to inspect boots, play, etc. Thanks for the replies.
  7. #7 Re: Front end creaking noise
    May 2016
    Rouge Island
    Give both sides a wiggle (3&9) and (12&6) with the wheels still on...more leverage that way. Then remove wheels and inspect further.
  8. #8 Re: Front end creaking noise
    Jul 2012
    Bloomington, IL
    Ok. This creaking is driving me nuts. I changed the transmission mount, and have wiggled and jiggled, and cannot figure this thing out. Could be the engine mount, but it looks like a real pain in the keester to change on the '07. I noticed this morning with the radio off, you can even even hear the creaking/rattling sound as you shut the car off, and the engine shakes to a stop.
  1. Creaking Noise From Top of Strut and Coil?
    By Konner27 in forum General Tech Discussion
    Last Post: 07-30-2015, 05:38 PM
  2. Creaking/Squeaking noise during acceleration or application of engine torque
    By densmith123 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-06-2012, 12:43 AM
  3. Creaking Popping noise from front end.
    By nawarkk in forum Brakes/Suspension/Chassis
    Last Post: 11-11-2010, 06:21 PM
  4. after tie rod repair- front creaking noise only while moving
    By torqueaddict in forum Brakes/Suspension/Chassis
    Last Post: 10-06-2010, 07:34 PM
  5. Creaking noise
    By BwolfGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-07-2010, 11:42 PM
