Thread: 2000 GTP PCode and other Troubleshooting (More GP's, More Problems)
Results 1 to 3 of 3
  1. #1 2000 GTP PCode and other Troubleshooting (More GP's, More Problems)
    Topeka, KS
    Working on my second GTP. I had it running for a few minutes until it decided to puke oil out of a cracked bolt hole in the front cover. But that's another story.
    I hooked my HP Tuners up last night just to see if it was displaying any codes as there are some weird electrical things going on.
    I found the following.
    P0102
    Probably a bad MAF sensor. My MAF split in half on me when I went to drill a hole in my intake pipe to put the IAT gromet in. Stuff happens, I epoxied the MAF back together hoping that it would still work. I don't think it does. I'm inquriring with Morad Parts Company on getting a replacement.
    P0443
    I found Bad Fuse in Underhood Electrical Fuse Panel #21, 15amp fuse.
    http://www.grandprixforums.net/threa...rk-plug-change
    P0230
    Fuel Pump Relay?
    http://www.grandprixforums.net/threa...-relay-circuit
    - Sidenote: This car has a Racetronix system going to PRJ's. The previous owner had the Racetronix wiring harness. I could not get the car to start without unplugging this harness and using the stock harness again. I checked the fuses etc. It was missing both FP relays and a FP fuse on the engine bay fuse area. I have replaced all 3 of those with a new fuse and 2 new relays.
    P0650
    Instrument cluster bulb?
    http://www.grandprixforums.net/threads/81955-P0650-code
    P1571
    ABS sensor, bad connector or wires possibly. Check that both are plugged in all the way.
    http://www.grandprixforums.net/threa...-Trac-Light-On
    Other Notes:
    This car previously had HIDS for headlights and fogs. The lights don't turn on and the front blinkers do not either.
    The horn doesn't blow so I replaced the plug that hooks into the horn as this was the problem on my 99 and it fixed that problem.
    - Sidenote: When you push on the horn the hazards flash on the dash and the high beam instrument light flashes all at once.
  2. #2 Re: 2000 GTP PCode and other Troubleshooting (More GP's, More Problems)
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    Quote Originally Posted by rynoman03 View Post
    Does it turn the actual exterior lights on when it does this? Because I need a horn like that. Lol
  3. #3 Re: 2000 GTP PCode and other Troubleshooting (More GP's, More Problems)
    Topeka, KS
    Sadly, I don't think so haha! Some days i'm tempted to install my old CB with the PA speaker to tell idiots to move.
    Well, I replaced the IGN fuse in slot #21 under the hood.
    Now I have 2 of the above PCodes showing up now.
    P0243: EVAP
    P0443: TURBO\SUPERCHARGER WASTEGATE SOLNOID
  1. 2000 gtp multiple problems....HELP
    By tjfrey517 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2012, 07:29 AM
  2. 2000 GTP Problems
    By BThomp in forum General Tech Discussion
    Last Post: 08-22-2010, 07:36 PM
  3. Problems with AC on 2000 GP
    By Aerosmitty in forum General Tech Discussion
    Last Post: 07-20-2010, 09:28 AM
  4. DIC Problems in GT 2000
    By sirpig34 in forum Audio, Security & Visual Electronics
    Last Post: 08-05-2009, 09:41 PM
  5. Troubleshooting Help! - A/C Problems
    By kappy332 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-21-2008, 04:07 PM
