Thread: oxygen sensor problem upstream
Results 1 to 3 of 3
  1. #1 oxygen sensor problem upstream
    NY
    hello, i am having a problem with my regal with its upstream oxygen sensor, i did replace it twice with denso ones, they both read 453 mv on the hp tuners, i cant figure out why they do not oscillate like they are suppose to and with the oxygen sensor not active the car goes into open loop and i can't see fuel trims. i orginally had a problem with the maf and i did swap it out for a working one. on the oxygen sensor its self the white and blue wires are both reading volt, one is 4.5 and the other 5.5. i just double checked the part numbers with denso to make sure i didn't have the wrong part. what kind of reading iam i suppose to be getting from the blue and white wire, i know the black ones are for heater.
  2. #2 Re: oxygen sensor problem upstream
    You sure you are reading the right sensor with HP Tuners?
    It should be bank 1 sensor 1.
    Double check any fuses too.
  3. #3 Re: oxygen sensor problem upstream
    NY
    Figured it out! Two bad denso oxygen sensors. I swapped one from my grand Prix over and it worked. Denso is sucking major balls at this point.
  1. oxygen sensor
    By kenjr in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-24-2013, 04:34 AM
  2. Oxygen Sensor
    By BwolfGT in forum Off Topic Discussion
    Last Post: 11-21-2009, 05:44 PM
  3. oxygen sensor
    By grand2000prixgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-14-2009, 06:20 PM
