Thread: 02 GTP Mysterious Intermittent Idle Surge
Results 1 to 6 of 6
  1. #1 02 GTP Mysterious Intermittent Idle Surge
    SE Level Member GP40TH's Avatar
    May 2012
    Green Bay, WI
    Hey Guys,
    My 02 GTP is experiencing an intermittent idle surge when warm (fluctuates between 300-1500 RPM at worst, sometimes stalls) which will usually last about 30 seconds. It happens when I'm coming to a stop in gear, and sometimes when I press the throttle for the first time after the car has been started if I leave it alone to warm up. If I rev it up, it revs just fine, and giving it a rev usually stops the surging once the engine returns to idle. The car acts like its hunting for the right idle speed, but drops too low, then compensates by revving up too high, then drops too low again (this is sometimes where it stalls), then revs up high, and so on. It's like an unstable control system, and its not shaking or running rough. In the meantime, I checked the short term fuel trim and it goes down to -15-20% during the surging behavior and it smells rich. I thought it could be the idle air control valve since the TPS was reading 0% while surging, so I replaced the IAC valve, but no luck there. What was really strange was that the MAF sensor was reading pretty steady values during the surging, and there aren't any check engine lights. Please help!
    Current DIC's: none
    Ongoing DIC's: P1844-
    Torque Reduction Signal Circuit Desired By TCM (predates the surging issue)
    CEL: not illuminated
    Reccent repairs:
    Battery: 2yrs old
    MAF Sensor: 6 months old
    Vacuum lines: Checked 6 months ago. Some replaced.
    Fuel Pressure Regulator: 6 months old
    Fuel Filter: 6 months old
    Injectors: Cleaned 6 months ago
    O2 Sensor: 6 months old
    TB: Cleaned 8 months ago
    Air Filter (Cone): 6 months old, pretty clean still
    Plugs and Wires: 6 months old
    IAC: Just replaced
    Engine Modifications:
    Cold air intake
    ZZP 1.0 PCM
    ZZP U-bend delete (w/out downstream O2 sensor)
    SLP Catback
  2. #2 Re: 02 GTP Mysterious Intermittent Idle Surge
    GT Level Member mguzzo's Avatar
    Buffalo NY
    unplug the MAF and see if it keeps doing it.
    also check vacuum lines, especially under the SC snout and the 180* U shaped line on the throttle body.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  3. #3 Re: 02 GTP Mysterious Intermittent Idle Surge
    May 2012
    Green Bay, WI
    When I unplug the MAF, it is even more likely to start surging. I'll check the lines again, but I just replaced the one on the TB last summer, and at the time the one under the snout wasn't leaking.
  4. #4 Re: 02 GTP Mysterious Intermittent Idle Surge
    St. Louis
    Did you unplug the MAF before you started the car to test? If not, try it that way. May need a little pedal to keep it running until the ECM figures it out then it should stay on its own.
  5. #5 Re: 02 GTP Mysterious Intermittent Idle Surge
    Aug 2016
    CT/RI Border
    Recall work been performed? Have you changed the LIM/UIM gaskets yet? Bad gaskets can be fine at cold/idle and as the car warms up air/fuel can get fubar'd
    Sent from my ASUS_Z00TD using Tapatalk
  6. #6 Re: 02 GTP Mysterious Intermittent Idle Surge
    Jan 2013
    Saint John, IN
    check the vacuum line under the MAP sensor. It can come loose and is not visible until the MAP sensor is taken off.
  1. Intermittent Idle Surge/Rough Idle
    By 99coupegtp in forum General Grand Prix Discussion
    Last Post: 07-31-2016, 05:11 PM
  2. Idle surge causes?
    By GTPChristopher in forum Turbo
    Last Post: 05-29-2016, 09:20 PM
  3. Idle Surge
    By Huckleberry in forum Engine
    Last Post: 12-30-2013, 01:00 PM
  4. Mysterious intermittent smoking Issue Solved-
    By 02 WS6 TA in forum General Tech Discussion
    Last Post: 03-15-2012, 06:36 AM
  5. 07 GXP ABS/Trac intermittent on/off with power surge??
    By TJWA07GXP in forum Brakes/Suspension/Chassis
    Last Post: 01-27-2012, 11:11 PM
