Thread: 08 Grand Prix mystery coolant leak
Results 1 to 6 of 6
  1. #1 08 Grand Prix mystery coolant leak
    Apr 2013
    seguin
    last night when I turned my car off I smelled a strong antifreeze smell..I opened the hood and there was coolant sprayed all over the battery and in the area but it never overheated or anything.i opened the hood this morning, topped off the recovery tank and started it up to see where the leak is coming from and NOTHING! I left it running for 10 minutes and not a drop of coolant...when I'm driving and it get up to operating temp I can smell coolant when I park but there is no leak anywhere that I can see.. Any ideas anyone?
  2. #2 Re: 08 Grand Prix mystery coolant leak
    Water pump weep hole, coolant elbow cracked or the front timing cover gasket are the most common leaks to see.
    Pressure test the cooling system is what I'd be doing.
  3. #3 Re: 08 Grand Prix mystery coolant leak
    GTP Level Member buickman104's Avatar
    NYC
    Is it possible for the thermostat to go bad and not open at proper temp which would causes excess pressure and coolant to blow out of the coolant reservoir? That might be something to look at.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  4. #4 Re: 08 Grand Prix mystery coolant leak
    Apr 2013
    seguin
    I just changed the thermostat last week...
    Sent from my C6743 using Tapatalk
  5. #5 Re: 08 Grand Prix mystery coolant leak
    Apr 2013
    seguin
    and if it's leaking from the water pump weep hole that means my pump is going bad right?
  6. #6 Re: 08 Grand Prix mystery coolant leak
    May 2012
    lebanon ohio
    Yes if it is leaking at weep hole you want to replace it. Also do yourself a favor if you haven't replaced the plastic elbows with metal I would do that too.
    07 base tinted windows led tails new wheels spo grills spo spoiler retrofit projectors transgo shift kit overkill tune inferno lip special edition rear lip 2.5 cat back dual exhaust
  1. Coolant leak on 2002 Grand Prix GT 3800
    By whiteta in forum General Grand Prix Discussion
    Last Post: 09-12-2014, 05:16 PM
  2. 2000 Grand Prix coolant leak
    By Rjsleeper in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-03-2013, 12:04 PM
  3. 2004 Grand Prix GT Slow Coolant Leak SOMEHWERE
    By GrandPrix666 in forum General Tech Discussion
    Last Post: 05-20-2013, 09:54 PM
  4. Mystery coolant leak
    By 04silverprix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-26-2011, 11:35 PM
  5. 93 Grand Prix stalling, running hot, coolant leak
    By thehollowaytape in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-07-2011, 10:46 PM
