Thread: Is My Engine On Its Way Out?
Page 5 of 5 FirstFirst ... 345
Results 81 to 98 of 98
  1. #1 Re: Is My Engine On Its Way Out?
    GT Level Member Pursell1911's Avatar
    Jan 2017
    Louisville, Kentucky
    I'm assuming lefty Loosey righty tightly
  2. #2 Re: Is My Engine On Its Way Out?
    Quote Originally Posted by Pursell1911 View Post
    yes, but peoples minds go full retard when they are on their backs taking a nut off a bolt.
  3. #3 Re: Is My Engine On Its Way Out?
    Jan 2017
    Lol. Got the first bolt off, had to put my man pants on.
  4. #4 Re: Is My Engine On Its Way Out?
    so both feet wedged on the car bottom, the free hand holding something else and then pulling with all you got?
  5. #5 Re: Is My Engine On Its Way Out?
    Jan 2017
    Well something like that I suppose. I had my free hand bracing the wrench so the socket didn't tilt while trying to remove the nut. I yelled when it finally broke I was so excited haha. I still have to get the other nut off of the bolt in front of the cat. It was dark by the time I got to that one, and I cracked my phone screen while trying to use it as a light source. So I sprayed the crap out of it with the PB Blaster. Going to try to tackle after work. I'm hoping the two nuts towards the back are easier. I'm assuming they will be as there is much more room to work with on those. Forgot to spray those with anything though, just hit me. FML.
  6. #6 Re: Is My Engine On Its Way Out?
    the two bolts to the cat back always tend to break, some times its a blessing if they snap off.
  7. #7 Re: Is My Engine On Its Way Out?
    Jan 2017
    okay, so what do I do if they break? I'm guessing I can just go get new ones at home depot?
  8. #8 Re: Is My Engine On Its Way Out?
    most stock dp's have studs, some dont, the new dp likely wont have studs, so you'll need new bolts any way. get some washers for the new hardware too.
  9. #9 Re: Is My Engine On Its Way Out?
    Jan 2017
    I know it's unrelated to this thread, but I found out why my Traction Control and ABS lights are on. I'm guessing the tow truck driver somehow cut the line / sensor when he was securing the vehicle with the tire straps. I was under the car working on the second bolt and noticed a cut wire coming from what appeared to be my brake, to somewhere up in the engine bay. I'm assuming that's the problem, and will look into that and address if my car comes back to life after I get the clogged exhaust out of there.
  10. #10 Re: Is My Engine On Its Way Out?
    Jan 2017
    ok great, thanks for the advice Scotty, I will take the gasket with me.
  11. #11 Re: Is My Engine On Its Way Out?
    Jan 2017
    ok, no it doesn't have studs. So just get whatever fits well? Buy a couple washers, and whatever nuts fit on the bolts I buy? Sounds easy enough.
  12. #12 Re: Is My Engine On Its Way Out?
    i took the gasket in the store with me and found bolts that fit though, then 4 washers and nuts. went with stainless steel bolts this last time round, see if they hold up, so far nothing else has, they all break when you take em out, even a year later as ive found out.
  13. #13 Re: Is My Engine On Its Way Out?
    GT Level Member Hpiracr28's Avatar
    Apr 2016
    Elmira, NY
    Just think of all the experience you'll have doing your own work. I won't dare pay a shop these days unless it comes to internal transmission work, or if I don't have the proper tools to do the job.
  14. #14 Re: Is My Engine On Its Way Out?
    Jan 2017
    ^ Great point. I had a 2000 Escort ZX2, little zippy go cart like car. That car seemed much easier to work on, but then again I was in the Marines at that time, and had access to the hobby shop which had lifts, any tool to do any repair, and the All Data program. I wish I had that program now, it's great. I probably should invest in a Chiltons, or Haynes for this car.
  15. #15 Re: Is My Engine On Its Way Out?
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    THIS IS the Chiltons/Haynes.....lol
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  16. #16 Re: Is My Engine On Its Way Out?
    Jan 2017
    Dwnpipe installed, and I have power again!!! Thank you ALL!!!
  17. #17 Re: Is My Engine On Its Way Out?
    clogged kitty once again.... cool.
  18. #18 Re: Is My Engine On Its Way Out?
    Jan 2017
    Yea I looked down into the cat, and there was what looked to be a solid layer of black, in assuming that's carbon? I bet it's been clogged the entire time I've owned the car, because when I test drive it, it seemed a bit more powerful.
  1. Replies: 10
    Last Post: 07-20-2021, 09:07 PM
  2. 2000 Grand Prix with series 1 Engine, Weirdest engine problem ever!
    By ElectricBlake in forum Introductions/Noob Questions
    Last Post: 01-19-2016, 12:15 AM
  3. Replies: 15
    Last Post: 01-25-2013, 03:05 PM
  4. Check Engine Light - Wont downshift, whine coming from engine
    By brandibissell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2012, 08:17 AM
  5. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
