Thread: Is My Engine On Its Way Out?
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 21 to 40 of 98
  1. #1 Re: Is My Engine On Its Way Out?
    need the cam on top of the engine so we can hear it better.
  2. #2 Re: Is My Engine On Its Way Out?
    GT Level Member Pursell1911's Avatar
    Jan 2017
    Louisville, Kentucky
    Ok, next smoke break I'll do that. Just went to lunch. Now the noise is gone but my car was shaking bad, but my CEL was not blinking.
  3. #3 Re: Is My Engine On Its Way Out?
    Jan 2017
    I'm wondering if the piston has already jacked up that plug, because what it's doing now sounds a lot like what happened to my wife. I never started the car prior to changing the plugs, so I don't know. But I'd bet one of the cylinders isn't firing.
  4. #4 Re: Is My Engine On Its Way Out?
    SE Level Member 01Blackgtp's Avatar
    May 2014
    Colorado
    Bent plug, constant misfire, I wonder if that cylinder tried to escape.
  5. #5 Re: Is My Engine On Its Way Out?
    Jan 2017
    Time to bust out the hot glue and fix that bad boy lol
  6. #6 Re: Is My Engine On Its Way Out?
    GTP Level Member CHI2000GTP's Avatar
    Dec 2015
    Chicago, IL
    Couldn't it be something less serious like a broken valve spring or bad lifter?
    2000 GTP 4DR - Stock
    243,000 miles
    CHICAGO, IL
    My Car: http://www.grandprixforums.com/members-rides/103740-lukes-gtp.html#post1443981
  7. #7 Re: Is My Engine On Its Way Out?
    Jan 2017
    How would I diagnose? I'm assuming I'll have to take off the valve cover. Will need assistance from YouTube for that.
  8. #8 Re: Is My Engine On Its Way Out?
    Dec 2015
    Chicago, IL
    There's a little bit of work involved, but nothing to crazy. Worst part might be putting the belt back on, or maybe removing the coil bracket... In any case, it's not rocket science. The bent spark plug suggests that something serious is wrong. But worth checking under the valve covers and looking at the springs. The lifters are a lot harder to get to. The whole top of the engine needs to come off.
    243,000 miles
    CHICAGO, IL
  9. #9 Re: Is My Engine On Its Way Out?
    start with a compression test, its easy, remove spark plugs, then install the tester hose in the plug holes one by one. your looking for one to be way lower then the rest. would be the one with the messed up plug is my guess.
    you can get a compression tester at most parts stores they do free rental. you just leave a deposit on the tool. ful refund when returned.
  10. #10 Re: Is My Engine On Its Way Out?
    i kinda already told ya how. ^^^^^^
    you need to crank the engine over with the tester screwed in each plug hole. you dont want it to start up, all plugs out will let it crank faster too.
    write down your findings as you test each cylinder.
  11. #11 Re: Is My Engine On Its Way Out?
    Dec 2015
    Chicago, IL
    Do what Scotty said. Compression test sounds like the best starting point. Considering that their is already a casualty (the spark plug), get the compression test done. If that comes back "All Clear", then take a look at the other stuff.
    243,000 miles
    CHICAGO, IL
  12. #12 Re: Is My Engine On Its Way Out?
    Jan 2017
    okay I'll look into that. One thing to note, I doubt it's my issue though, I didn't tighten the new plugs with a torque wrench. Never have on a car [just found out that it's suggested to torque them down to a specific pressure(?)]
    How do I do the compression test? Car running, pull one plug at a time, stick hose in, get reading, put plug/wire back in, on to the next?
  13. #13 Re: Is My Engine On Its Way Out?
    Jan 2017
    okay, will this give me the same yes or no answer as to the touch the exhaust manifold trick? What am I trying to find with the compression test? To see if one of the cylinders isn't being utilized?
  14. #14 Re: Is My Engine On Its Way Out?
    one could be much much lower then the rest. they should be in the 150 psi range at min, they all should be with in 10 psi or so of each other.
    and that pipes gonna get hot still cause its got spark still. you might see a difference with a temp laser gun
    if you can hear it clicking under the valve cover id think busted spring. you can do the old screw driver to the ear and engine parts to listen more closely.
  15. #15 Re: Is My Engine On Its Way Out?
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    A broken piston will have low or no compression compared to the rest.
  16. #16 Re: Is My Engine On Its Way Out?
    May 2008
    Schuyler, NE
    Your video definitely sounds like you have spun a bearing. If that's the case, a compression test won't tell you anything. But I would venture to guess you are missing part of your piston too. What does your oil look like? Does it look like there is glitter in it?
  17. #17 Re: Is My Engine On Its Way Out?
    meet chip, hes an asshole who can and will ruin the party.....
  18. #18 Re: Is My Engine On Its Way Out?
    Jan 2017
    What's the top of the piston (where it's chipped) made out of? At one point I had the noise which can be heard in the video. Now I don't hear that noise but engine is way rougher. I guess the engine ate itself. I don't know what to do now. Don't have the funds to fix right now, and don't know if I even want to. I love this car, it's fun, but I just don't think the previous owner took very good care of it and it seems like it's falling apart. I think I'm going to go look for a different car with less miles for now, and park the GT and put a tarp on it and save it for down the road when I'm in a better financial situation. I really appreciate all of the help I've received from this forum over the past few months. We are blessed to have people like you all who have the desire to help.
  19. #19 Re: Is My Engine On Its Way Out?
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    I dropped a valve (broken spring) in my 03, CEL was flashing fast, then slow, then fast etc. It was saying "PAY ATTENTION TO ME, I'M SERIOUS".....lol As "luck would have it, #3 was busted, could be seen through oil fill in valve cover.
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  20. #20 Re: Is My Engine On Its Way Out?
    That sounds like my silver car when I spun a bearing in it.
  1. Replies: 10
    Last Post: 07-20-2021, 09:07 PM
  2. 2000 Grand Prix with series 1 Engine, Weirdest engine problem ever!
    By ElectricBlake in forum Introductions/Noob Questions
    Last Post: 01-19-2016, 12:15 AM
  3. Replies: 15
    Last Post: 01-25-2013, 03:05 PM
  4. Check Engine Light - Wont downshift, whine coming from engine
    By brandibissell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2012, 08:17 AM
  5. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
