Thread: wheel sensor problem ???
Results 1 to 5 of 5
  1. #1 wheel sensor problem ???
    Jan 2015
    illinois
    i had a hub bearing replaced which was really changing the whole hub and wheel sensor . about a month later my abs light and tcs would come on and go off so i was checking connection of wheel sensor and the sensor was loose from the mounting clip and the wires had been bared tried taping the up but now light is on all the time the sensor is built into hub and i dont want to change whole hub again. is there a way to get the lights off
  2. #2 Re: wheel sensor problem ???
    You could pull the bulbs or warranty out the bearing again.
    I'd suggest replacing the bearing again.
  3. #3 Re: wheel sensor problem ???
    SWPA
    You act like changing the hub is difficult. It's a 30 minute job.
  4. #4 Re: wheel sensor problem ???
    Jan 2015
    illinois
    it costs about 75 if i remember
  5. #5 Re: wheel sensor problem ???
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by weissmertz View Post
    You can remove the ABS fuse under the hood. This will also disable your A/C.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. Wheel sensor going bad again in new hub?
    By 2004l67 in forum Brakes/Suspension/Chassis
    Last Post: 06-10-2015, 06:27 AM
  2. wheel speed sensor issues
    By jhintz in forum General Grand Prix Discussion
    Last Post: 05-19-2014, 05:26 PM
  3. Wheel Speed Sensor
    By blackthunder in forum General Tech Discussion
    Last Post: 02-26-2014, 12:05 AM
  4. Wheel speed sensor
    By GXPrunner06 in forum General Tech Discussion
    Last Post: 03-22-2013, 10:30 AM
  5. ABS Wheel Sensor Harness, HELP
    By foursixer in forum General Tech Discussion
    Last Post: 04-14-2012, 10:38 PM
