Thread: Engine Trouble - Need Help
Page 1 of 3 123 LastLast
Results 1 to 20 of 55
  1. #1 Engine Trouble - Need Help
    GT Level Member Pursell1911's Avatar
    Jan 2017
    Louisville, Kentucky
    Hey all, I'm new to this forum and I need some guidance regarding my 2007 Grand Prix GT. I purchased the car a few months ago from a family friend. There is an issue with my engine (I think). Here's what's happening...
    When I'm in gear and reach right about 4000rpm, I hear a loud clicking noise, and lose all power. If I let off the gas a little, the transmission will shift and all is well. But I can't get over 4000rpm. Aside from that issue, everything seems to work well with the car. I've searched all over the place for answers for this problem I'm having, but I can't find any other cases of this issue...Don't know the first thing about SC's so thought it could possibly be related to that, but don't know.
    Thanks all!
  2. #2 Re: Engine Trouble - Need Help
    Jan 2017
    I believe I tried that, and the issue occurred. The car is in the shop right now for an unrelated issue, so I will check when I pick it up later this afternoon. But I'm pretty sure the answer to your question is no, it will not go above 4k while in 1st gear.
  3. #3 Re: Engine Trouble - Need Help
    Jul 2010
    Coquitlam,BC,Canada
    Can you rev past 4000 rpm in neutral?
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  4. #4 Re: Engine Trouble - Need Help
    Jan 2017
    I'm probably wrong here, but doesn't the computer limit past 4k rpm in P or N? I can try that when I get the car back later today.
  5. #5 Re: Engine Trouble - Need Help
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by Pursell1911 View Post
    Not on any car I've ever owned or worked on.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  6. #6 Re: Engine Trouble - Need Help
    Quote Originally Posted by Bronco Boy View Post
    you have a rpm limiter in park and neutral, 4,000 rpm it is.
    is the check engine light on, or does it flash when you floor it?
  7. #7 Re: Engine Trouble - Need Help
    Jul 2010
    Coquitlam,BC,Canada
    Really? Could have sworn I've revved her over 4K in park. Now I must go try. LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  8. #8 Re: Engine Trouble - Need Help
    GTP Level Member
    Oct 2014
    Yep it cuts out. Scottys right again.
  9. #9 Re: Engine Trouble - Need Help
    Jan 2017
    ok, I guess I shouldn't believe everything I see on the net lol. I will check and post the result.
  10. #10 Re: Engine Trouble - Need Help
    May 2008
    Schuyler, NE
    Sounds to me like your cat is clogged.
  11. #11 Re: Engine Trouble - Need Help
    floor it and hold it there, it will do the famous ricer limiter rpm cut out gayness.
  12. #12 Re: Engine Trouble - Need Help
    Jul 2010
    Coquitlam,BC,Canada
    OMG, that was gay. I hate that! LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  13. #13 Re: Engine Trouble - Need Help
    Jan 2017
    Yes, my check engine light is on, but the mechanic just told me it's no longer on, but he may have just reset it? Not sure. I will check to see if it flashes when I floor it. I will test and post the results.
  14. #14 Re: Engine Trouble - Need Help
    Jan 2017
    So I got my car back and tested. When locked in 1st gear, I can go above 4K rpm. When in drive, there is fast and loud clicking. Note - the transmission shifts very smooth under 3500 rpm. Not sure if that helps or not. Check engine light is not on anymore.
  15. #15 Re: Engine Trouble - Need Help
    GTP Level Member
    Oct 2014
    Take a video and post.
  16. #16 Re: Engine Trouble - Need Help
    Jan 2017
    https://youtu.be/0wK_2aF-LKI
    so here is the link to the video I just uploaded. Also, my previous comment was not accurate. This is still occurring when in 1st only. From what I can tell, this is happening when the SC gauge is all the way up. Hope this helps.
  17. #17 Re: Engine Trouble - Need Help
    Jul 2010
    Coquitlam,BC,Canada
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  18. #18 Re: Engine Trouble - Need Help
    wow, no idea wtf that is. being under the bridge made it sound pretty bad. you feel that in any way? your cel on there? looks like it, but im not up on the gp dash. if its on, get it scanned at a parts store. its free. if it turns off when you restart it, dont turn the car off, scan it running. tranny codes can some times clear themselves when restarted.
  19. #19 Re: Engine Trouble - Need Help
    Jan 2017
    I did it under the bridge so the noise would be more distinct. No I don't feel anything, CEL is on, I'll go get it checked.
  20. #20 Re: Engine Trouble - Need Help
    GTP Level Member
    Oct 2014
    Crazy noise. No idea. I don't know how a flex plate works but it would seem like it would always make noise if related to that.
  1. Engine Trouble
    By CotyF03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-23-2015, 04:44 PM
  2. 98 gtp new guy engine trouble
    By JayHolyj in forum Introductions/Noob Questions
    Last Post: 02-20-2012, 11:58 AM
  3. 3.8 engine trouble
    By mjacob in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-10-2011, 11:37 AM
  4. Engine Trouble
    By 98GTFan in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-10-2011, 03:58 PM
  5. Engine Trouble!! need help!
    By ddrum in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-12-2010, 04:41 PM
