Thread: Coolant Flush Question
Results 1 to 10 of 10
  1. #1 Coolant Flush Question
    Oct 2016
    Canada
    I recently purchased a 2007 base model Grand Prix and would like to try and perform a full coolant flush. I've never attempted to do a coolant flush before but my plan is to remove the upper and lower radiator hoses, the heater core hoses and flush the radiator, engine block and heater core with a garden hose in both directions until the water drains clear from all three. Then put in a new T-stat, reassemble and re-fill.
    my questions are
    1)is this an acceptable method of flushing the coolant system?
    2)roughly how much water will be left in the system after the flush so i can adjust the water to coolant ratio?
    3)should I re-fill with dex-cool as per the manual or switch to something else for any benefit?
    4)how do I go about removing air pockets other then squeezing the hoses by hand and letting the engine run?
    any advise. tips or tricks would be greatly appreciated thanks.
  2. #2 Re: Coolant Flush Question
    how to flush coolant:
    remove the t stat, put the t stat housing back on, take the upper hose off the radiator, then push it down to the ground to a bucket or let it fly.
    get your garden hose out, put it in the rad turn it on, then fire up the car, let it run till clear water pumps out the top hose.
    then turn the hose off, run the car till no more water comes out the upper hose. then turn it off.
    put your t stat back in, with new gasket, the upper hose back on.
    now take 1 gallon of full strength green antifreeze, not the 50/50 crap. ( parts store cheap green is fine to use) dump the whole gallon in the radiator, fire up the car, fill the rad with hose water till its full. top as needed till its ready to be bled of air. it will burp and take coolant as the water in the block warms up the t stat opens up for a few seconds till cold coolant hits it and it shuts again.
    now to bleed the air out, let it idle rad cap off till the fans turn on, (when the fans are on the temp is over 195 deg, the t stat is wide open) then open the bleeder screw on top the t stat housing a few turns till a steady stream of coolant comes out the hole, shut the screw, top off the rad. cap it.
  3. #3 Re: Coolant Flush Question
    I prefer to fill the coolant via the thermostat opening instead of only the radiator. This require less bleed time and even no bleed time.
    The thermostat opening is higher than the radiator and should help all the air escape.
  4. #4 Re: Coolant Flush Question
    Oct 2016
    Canada
    wont running the car until there is no coolant damage the water pump?
  5. #5 Re: Coolant Flush Question
    Not at as ll. Not lije theres a rubber impeller or anything.
  6. #6 Re: Coolant Flush Question
    GTP Level Member
    Aug 2012
    st louis park, MN
    I switched to green last year after flushing completely with water. No issues and no more worrying about Dexcool so I'd recommend switching to green.
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  7. #7 Re: Coolant Flush Question
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by TheRiGuy View Post
    Flush all the dex-cool out and go green. Dex-cool is for suckers.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  8. #8 Re: Coolant Flush Question
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    While you have all that apart, I would strongly suggest changing your coolant elbows to the aluminum ones. They're under 20$, cheap for peace of mind. Factory plastic ones will fail sooner or later. Not very difficult, 90 minutes tops, no special tools. Good luck! And count me in the Dexcool blows club...Greens cheaper anyway...
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  9. #9 Re: Coolant Flush Question
    Oct 2016
    Canada
    Thanks for all the advice everyone. I guess I'll be going green lol, not much love for dex-cool here it seems. I will definitely be sure to upgrade those elbows to aluminum while I'm at it.
  10. #10 Re: Coolant Flush Question
    metal elbows are in the help section at most parts stores, they run about 10 bucks. when you change them, clean the holes out really good, use some 120 grit sand paper if you have it in all 3 holes.
    then oil the o rings on the new elbows and slide them in. not sure what year you got, but watch them alt bracket bolts, use the long one in the wrong place and you drive it into the valve cover and make a nice hole in it.
  1. coolant flush question
    By 310toumad in forum General Tech Discussion
    Last Post: 06-23-2016, 04:22 PM
  2. Coolant Flush
    By Logan541 in forum General Tech Discussion
    Last Post: 08-25-2015, 11:15 AM
  3. Coolant Flush
    By donjo in forum 5.3L V8 (LS4)
    Last Post: 08-05-2015, 05:22 PM
  4. Transmission/ Coolant Flush Question and Problems
    By Blacknight02GT in forum General Tech Discussion
    Last Post: 07-17-2009, 03:03 PM
  5. Going to vip for a coolant flush
    Last Post: 03-12-2008, 03:42 AM
