Thread: good aftermarket headlight housings
Results 1 to 19 of 19
  1. #1 good aftermarket headlight housings
    Nov 2016
    N. California
    At the risk of posting an oxymoron, are there any good aftermarket headlight housings for my 2001 Grand Prix GTP? The stockers are like candles in a bucket with the yellowed plastic. Will probably combine these with Philips extreme vision halogens. Not really looking to do HID or LED.
    edit: I see Rockauto lists the following
    TYC NSF certified $34
    TYC CAPA certified $73
    Dorman $48
    Are there any differences in quality, sealing of moisture, etc? I am willing to pay more if the product is actually better. From my experience, aftermarket plastic headlights are not always well made.
    Thanks,
    Lifespeed
  2. #2 Re: good aftermarket headlight housings
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    The ones that suck are Ebay Spyder projectors for 04+, all the rest are about the same quality.
    Have you looked at restoring the originals, or are they too far gone?
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  3. #3 Re: good aftermarket headlight housings
    Nov 2016
    N. California
    Quote Originally Posted by WarStryker13 View Post
    They're definitely too far gone.
  4. #4 Re: good aftermarket headlight housings
    I'd probably bought somewhere around 6 or 8 headlights from Rockauto and they were the TYC brand. It was always around 70-80 for the pair.
    Never had any real problems with them, maybe one or two got condensation build up on the inside but that was an easy fix with a second breather hole in the bottom of the housing. The brackets are actually pretty nice if you ask me too, no real headlight bounce with the cars I've installed them on. Used several sets for making projector retro-fits too.
  5. #5 Re: good aftermarket headlight housings
    Jul 2010
    Coquitlam,BC,Canada
    As already noted, TYC from RockAuto.....
    The only thing better is retro-fits. Do we need to go there? LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  6. #6 Re: good aftermarket headlight housings
    Nov 2016
    N. California
    Any idea why the price difference between TYC CAPA and TYC NSF? It seems odd the same vendor would make two different versions for the same car. Three if you count Dorman, but they're a different mfg.
  7. #7 Re: good aftermarket headlight housings
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    I used some TYC. They are garbage. The clear coating on them starting coming off after about 18 months. That was with maybe 10k miles put on during that time. Aggravating as hell.
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  8. #8 Re: good aftermarket headlight housings
    GTP Level Member
    Oct 2014
    Got about 6 months on some TYC NSF and still look good. I'll be happy if they are good for a couple years. Heck the OEM ones yellow in about 5 years.
  9. #9 Re: good aftermarket headlight housings
    Don't buy the Eagle Eye brand, they fog up and the brackets are made out of butter soft plastic and the headlights bounce all over the place.
  10. #10 Re: good aftermarket headlight housings
    I had my first set of TYC lights for like 3-4 years, even removed them and had them in a box for a while my retro-fits were installed. Re-installed them for a few months and sold my car with them.
    Put a set on my sisters car a 2+ years ago and they still look good.
  11. #11 Re: good aftermarket headlight housings
    Nov 2012
    Madison
    80 dollars.is cheap for a couple years.
    Try to keep some variety of sealant on them to help protect them from uv.
    Every week if you have to. I have some 2 1/2 years old and they are like new.
    Then again I coated mine with opti- lens when they were new and some form of drying aid when I wash(which now is opti-seal)
  12. #12 Re: good aftermarket headlight housings
    GTP Level Member buickman104's Avatar
    NYC
    My TYC brackets are garbage. They bounce all over the place and vibrate the light beam while just idling.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  13. #13 Re: good aftermarket headlight housings
    Nov 2016
    N. California
    Quote Originally Posted by LeadfootCJ7 View Post
    Quote Originally Posted by Slick2500 View Post
    Quote Originally Posted by buickman104 View Post
    And this is the reason for my post. Not surprising that a $34 plastic headlight is garbage. Too bad the mfg's don't consider we might pay more for non-garbage. I guess my other options are Dorman or TYC CAPA. I have no idea what TYC CAPA is, nor have any reason to believe it is a better product other than it is more expensive. And wouldn't that be funny if that were the only difference, same headlight but double the price with no other differences?
    Edit: CAPA is an auto parts quality testing organization. I called Rockauto and the claim is parts that pass CAPA are often manufactured differently. I guess I'll give them a try . . .
  14. #14 Re: good aftermarket headlight housings
    NYC
    Let us know how they work out for you. Hopefully the extra cost is worth it.
  15. #15 Re: good aftermarket headlight housings
    Nov 2016
    N. California
    Was planning to install these tonight, is it an easy job?
  16. #16 Re: good aftermarket headlight housings
    GTP Level Member
    Oct 2014
    Yes 10 min
  17. #17 Re: good aftermarket headlight housings
    Nov 2016
    N. California
    It was a bit of a mixed bag, and took me longer than 10 minutes because I hadn't done it before. One out of two plastic tits on the edge of one corner lamp broke with very little force applied. Still stays in place, and other than that they seem decent. They are mounted securely and don't vibrate at an idle. The headlights are Sylvania (included), but the marker lamps had to be re-used.
    They're a lot brighter of course, and the aim doesn't appear to be off by a mile, although I'll have to do a proper aiming soon. Thanks to all for the advice.
  18. #18 Re: good aftermarket headlight housings
    SE Level Member RonsGTP's Avatar
    Apr 2015
    San Antonio, Texas
    I recently bought these ones. I'm pretty happy with them these have a slight tint but you can buy clear, tint and black.
    http://www.autoanything.com/lights/77A5221A4215981.aspx
    1999 Black GTP (stock)
    2017 ZL1 (Red Hot)
    2016 Camaro SS (wife's car)
  19. #19 Re: good aftermarket headlight housings
    Apr 2015
    San Antonio, Texas
    2017 ZL1 (Red Hot)
  1. condesation in new headlight housings
    By 2004GrandPrixGT1 in forum Visual/Body Modifications
    Last Post: 11-26-2012, 01:31 PM
