Thread: I'm mounting gauges, wheres the bestplace to run through the firewall?
Results 1 to 3 of 3
  1. #1 I'm mounting gauges, wheres the bestplace to run through the firewall?
    Slower, Lower Delaware
    I know I've seen this somewhere but I can't find it. I've searched but had no luck. I've mounted a pillar pod with boost and AFR.
    Where's the best place to run these through the firewall.
    TIA
  2. #2 Re: I'm mounting gauges, wheres the bestplace to run through the firewall?
    Omaha, NE
    There's a grommet on the passenger side that works great. It comes out below the dash.
  3. #3 Re: I'm mounting gauges, wheres the bestplace to run through the firewall?
    GT Level Member mguzzo's Avatar
    Buffalo NY
    through the passenger side grommet, or through the steering shaft grommet which exits under the brake booster.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  1. Drilling a hole in the firewall for extra gauges/electronics?
    By Wotgtp in forum Audio, Security & Visual Electronics
    Last Post: 04-15-2013, 11:57 AM
  2. Wheres TBS?
    By CoolblueGTP2000 in forum General Tech Discussion
    Last Post: 02-22-2013, 11:20 AM
  3. Wheres my pcm?
    By Nathan07GP in forum PCM Tuning
    Last Post: 09-11-2012, 10:43 PM
  4. wheres the amp?
    By lorenzojay in forum Audio, Security & Visual Electronics
    Last Post: 10-07-2009, 10:19 PM
  5. Hey Wheres wisconsiniets
    By Krazicustom in forum Introductions/Noob Questions
    Last Post: 03-15-2008, 08:45 PM
