Thread: Tire Monitoring System
Results 1 to 9 of 9
  1. #1 Tire Monitoring System
    Oct 2016
    Canada
    this is my first time posting on these forums so hello everyone.
    I recently purchased a 2007 Pontiac Grand Prix base model. It has 156,000kms, engine runs great and it's very clean inside and out. When I bought it, it had no warning/indicator lights on but of course a week later the tire pressure light came on. the yellow light flashes for about a minute then stays solid every time I start the car. also the DIC displays "Service Tire Monitor System". going through the DIC I can see that it only shows a pressure for one tire (Rear driver side) and nothing for the rest. all tires are at 30psi.
    I did a bit of research on the issue and read that the actual sensors are part of the valve stem and the valve stems will be metal. but when I look at all my tires they are all rubber stems except the front driver side which is metal but not the one the DIC is showing a reading for.
    Questions
    -Does this mean I'm missing three of the four sensors?
    -If that's the case why wasn't the warning light on before?
    -Can I just get new sensors installed to get rid of the warning light?
    -Will this have any effect on the ABS system or anything else?
    -Is there any other way to get rid of the warning without buying new sensors?
  2. #2 Re: Tire Monitoring System
    Omaha, NE
    Most likely, yes. It looks like 3 tires were probably replaced, which would be why the valve stems looks new compared to the other one.
    How long have you had the car? You said it was a recent purchase. The seller could have cleared the code prior to you buying it.
    Yes.
    Traction Control and ABS may be impacted. Also, if your tires are low, it will affect speedometer readings.
    You could have the code tuned out. I believe HPTuners can disable the low tire MIL.
  3. #3 Re: Tire Monitoring System
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    Welcome RiGuy from a real R.I. guy. This is a real cool place to forum, take some time, bump around, chip in when you can, we all win.
    BTW your car looks like a twin of my 06 base. Also looks like you could use some headlight restoration...pretty easy, they almost pop right out on these cars, don't forget the fog/running lights too....E
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  4. #4 Re: Tire Monitoring System
    Oct 2016
    Canada
    Thanks for the info. I'll probably just buy four new sensors and have them installed at a local tire shop.
    Can anyone tell me if this is the right sensor? (Link) If I'm going to spend $160 on four new sensors I'd like to make sure I'm getting the right ones
    Quote Originally Posted by cheatah faheatah View Post
    I've tried using those headlight restoring kits before on my last car (2001 GP GT) it looked great for a few months but didn't take long to fog up again. I might try it again on these or I'll just buy new housings off RockAuto and have the car looking brand new
  5. #5 Re: Tire Monitoring System
    May 2016
    Rouge Island
    I used the Meguiars kit that comes with UV protectant that you apply after....afew months, so far so good....E
  6. #6 Re: Tire Monitoring System
    Many new sensors use rubber valve stems now because the metal ones break and corrosion in the winter kills them.
    I'd ask a tire shop to scan each wheel and see what wheels still work but it's still possible they are regular valve stems with no sensors.
    TPMS lights do not talk with the ABS or anything traction control related. Also HP Tuners does nothing with BCM/ABS functions, I just wanted to add those two so nobody looks for this thread in the future and thinks they are true.
  7. #7 Re: Tire Monitoring System
    GTP Level Member
    Aug 2012
    st louis park, MN
    You may have sensors in there they just need to be reset. It should say how to do that in your owner's manual. I would try that before ordering new ones.
    The 1 new sensor/valve stem I have is rubber like the one you have pictured while the rest are still metal.
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  8. #8 Re: Tire Monitoring System
    Oct 2016
    Canada
    Quote Originally Posted by stocker View Post
    I'm thinking that might be the case. Today I was cleaning the throttle body and disconnected the battery to avoid getting a code and when I re-connected it the tire pressure light was gone and the three sensors have a reading of 889 kPa on the DIC. obviously not correct but its not nothing. The reset/ learn instructions require holding down the lock and unlock buttons on the factory remote which is broken and requires re-soldering the battery holder to the board and I don't own a soldering iron. tried holding the buttons down on my command start remote but it doesn't work.
  9. #9 Re: Tire Monitoring System
    GTP Level Member
    Aug 2012
    st louis park, MN
    Quote Originally Posted by TheRiGuy View Post
    Some people have repaired their factory remote with foil tape. Search around on here for those how-to's and you may be able to find a fix that doesn't require soldering.
  1. Tire Pressure Monitring System
    By sawsb1989 in forum Introductions/Noob Questions
    Last Post: 04-06-2013, 09:29 AM
  2. question about tire monitoring system
    By DirtDog in forum Tires & Wheels
    Last Post: 01-06-2013, 09:37 PM
  3. How to reset tire pressure monitoring system?
    By gpcruzin in forum Tires & Wheels
    Last Post: 12-07-2011, 12:06 PM
  4. Chrome Wheels/Tire Monitoring System
    By cmw1876 in forum General Tech Discussion
    Last Post: 03-28-2009, 02:11 PM
  5. tire pressure monitoring system light
    By uti grand prix in forum General Tech Discussion
    Last Post: 10-02-2008, 09:13 PM
